-   -   oh, im leaking oil too UPDATE (http://forums.sv650.org/showthread.php?t=78640)
BILLY 08-10-06 09:28 AM
It was just a thought because the O ring is suppost to be changed every time the bolt is removed!!!
hovis 08-10-06 11:10 AM
while im ther i might change oil & filter MYSELF it had a service 2000 miles ago??
northwind 08-10-06 07:15 PM
I accuse the clutch casing o-ring... Or rather, the clutch casing itself, which can warp. Get the lowers off, clean the engine up as well as you can, ride it for a bit and see where the oil is.
dirtydog 08-10-06 07:41 PM
That was what i was thinking it could be, it's the normal culprit
jambo 09-10-06 09:26 AM
The oil is supposed to be changed every 3500 / 4000 miles odd as relates to the service schedule, changing the oil at 2000 miles is a waste of time money and effort IMO.
TSM 09-10-06 09:44 AM
I have a major oil leak but i recon its either the drive shaft/clutch push rod oil seal, unforunatly the front sprocket has to be removed to change either of them. Grr.
jambo 09-10-06 09:53 AM
Check the torque on the front sprocket seem to remember if this is not tight enough you can end up with oil coming past the seal.
hovis 09-10-06 10:22 AM
ok, i wont :oops:
Grinch 09-10-06 10:36 AM
Mine leaks... sometimes it doesn't... the engine has taken a whack and just ain't the same. Seems to seap a bit round the right hand cover, had the gasget replaced but after time it just seems to go.
TSM 09-10-06 10:44 AM
Yep checked that, put the breaker bar on it and made sure it was tight.
