Re: advice needed urgent
I know I know, if its repaired properly etc etc, but I still wouldnt buy a cat C or Cat D bike. Unless I was 100% sure that it had been repaired properly and I dont know enough about bikes to be able to be confident in my mind that it had been.
If the bllokes not willing to move on the price then I'd walk away, I've never paid full asking price for any vehicle I've bought. However here are a few things to look for when your looking at SV's this isnt a definitive guide by any means, but should point you in the right direction 1. Look at the front forks are they corroded and chipped, This is pretty common on a high milleage SV thats been used in all weathers. Its a good indication of what the bikes been used for and also if the milleage is correct. i.e if the forks are chipped and manky but the milleage on the bike is low then start asking questions. Same goes for the handlebars and footpegs. 2. Have a look at the disks and pads. What condition are they in. SV's are known for the brakes sticking on if its not been looked after. Again this is especially relevant if its been used through winter and neglected. 3. Look at the chain and sprocket and the tyres. how much life do they have left in them, and slack worn chain with hooked teeth on the sprocket mean that its going to want changing soon. 3. Electrics, some people including me have had trouble with blown fuses caused by the wiring loom rubbing on the tank. So ask about that to. 4. If its a private sale, if you can get a sneaky peak in the owners garage, have a look for stuff like, paddock stands, a good set of tools, cleaning products, chain lube etc on the shelf, It'll give you an idea of how the current owner looks after the bike. 5. Sometimes if the bikes ridden in heavy rain water gets into the front spark plug hole and then it'll drop down onto one cylinder and run intermitantly between one two cylinders which isnt fun. A fenda extenda will sort this or some silicone grease on the front HT lead will also do the trick, have a search for the subject its been covered loads of times and its fairly common. Ask the owner if they have had trouble with the bike in the wet, its not a huge problem and its easy to sort. Dont be put off by high milleage as long as you can see that the servicing has been done, either by stamps in the service manual or receipts for parts used. A high milleage bike thats been ridden is better than a low milleage bike thats been stood for ages and has got all seized up. Use things like worn tyres, chain and sprocket as bargaining tools to get the price down. Make sure you do a HPI check to make sure that theres no outstanding finance or the bike hasnt been involved in a accident at some point in its life. Remember that non standard parts dont increase the value of the bike. So dont let the bling bits distract you from the of the bike, better IMHO to buy a mint standard bike than sh*tter with loads of aftermarket parts bolted onto it. Things like a hugger, a scotoiler are sensible modifications though as is a race can but only if you like the sound / look of it. I'm also wary of bikes plastered in stickers or non standard paint schemes, what are they hiding ? If you're not sure, Walk away from the bike, or take somebody with you who does know what they are looking at. Make sure you look at plenty of bikes and never buy the first one you look at. Hope thats useful |
If I'm right, a cat c bike required a VIC once repaired, whereas cat d doesn't
i think that applies to cars only.
You learn something new everyday, ta kwak
i looked into when i did my last crashed bike up:)
it was on men and motors the other day "wrecks to riches" and it said VIC doesn't check the standard of work done it looks for stolen cars that have been given a new identity.
What fizz said but £1K is already cheap even for a cat C- depends on condition, but sounds like he's already taken the cat C into account when pricing it.
http://cgi.ebay.co.uk/2000-Suzuki-SV...QQcmdZViewItem See, that's the price before it's been repaired |
Another couple of points.
Bikes are cheap this time of year as no one (except you) is buying.An old curvy is a cheap bike anyway previous write off or not,so if the cat c bikes are not very significantly cheaper then buy a non write off. Also---a bike whose mileage cant be verified by service history and old MOTs is a high mileage bike to you as a buyer.Price it accordingly.My lad bought a Y plate curvy for £600 a year and a half ago because it had done 68000 miles. Never pay the asking price.;) |
