-   -   Curvy Stator Issues. Bike cuts out (http://forums.sv650.org/showthread.php?t=231708)
johnnyrod 10-01-19 09:52 PM
Re: Curvy Stator Issues. Bike cuts out
Fair dos. The sticking choke is mainly the plungers themselves, mine builds up a bit of crap where the plunger seats so it won't shut off properly.
Muss60 20-01-19 08:42 PM
I have same issue with 2001 curvey, Alternator coils checked out, but battery and the bike die after 20 ish miles.
In the end I had faulty alternator coil, which shorted when hot, the lacquer insulation on the coils had small cracks which opened up to create an electrical short path.
After fitting a new alternator and cover gasket I had a problem with the bike stalling at junctions or traffic lights.
As the fuel tank had been moved to remove and re-route the new alternator harness it is common to trap the fuel tank breathers, which can also cause the bike to stall when idling, as in my case.
johnnyrod 21-01-19 12:02 PM
Interesting, thanks for sharing. I suspect your alternator was living on borrowed time, once any sort of short circuit starts in the windings they burn out fairly quickly.
Muss60 01-02-19 02:43 PM
Yes, the technical term F***ed.
While at Lucas some fair years ago now, the same used to happen to their alternators, mainly they failed due to the in built rectifier diode packs though.
I believe the hot oil can age the lacquer quickly.
Goldy69 25-05-20 01:58 PM
Chris did you ever solve this? Mine have very similar issues
