Old 21-04-05, 06:27 PM   #11
Flamin_Squirrel
Originally Posted by jonboy
Originally Posted by Flamin_Squirrel
Originally Posted by Wiltshire7
oscillation
thats a damn good word. im gonna start using it.
'how r u oscilating today?'
im not convinced i know what it means though
A pendulum, for example, oscilates. It basicaly means move back n forth.
http://dictionary.reference.com/search?r=2&q=oscillate
An oscillation is an eliptical path not just a linear movement back and forth.
You mean sineusoidal, I'm an engineer you know! I just didn't want to confuse the guy with further geometric jargon Hence the word, 'basicaly'
Old 21-04-05, 06:29 PM   #12
embee
embee's Avatar
sounds a bit like your ar$e-uppards set up won't help, but other things are steering head bearings loose (tight tends to give a slow weave at low speed, loose tends to give wobbles typically at around 40mph and worse on overrun).
Also front tyre not suited to the bike (carcass stiffness) or wrong pressure can do it.
I'd suggest check the fork legs/yokes aren't twisted (suspension bumps can then input a turning effect)
Old 21-04-05, 08:05 PM   #13
jonboy
Look this is a "U" rated site so please refrain from using language like that in future.
Old 21-04-05, 09:24 PM   #14
weegaz22
oscillation
you would know wouldnt you?
Old 21-04-05, 09:29 PM   #15
Warren
oscillation
well tell you what . . . i dont know.
Old 22-04-05, 08:39 AM   #16
jonboy
oscillation
Fixed now, with forks done and head-race bearing tightened up.
You haven't been about much, you you doin'?
Old 22-04-05, 03:40 PM   #17
weegaz22
oscillation
been working and trying to get the flat i bought sorted so havent had much time to come on the board, but seeing as summer is here i think ill be on a bit more now
Old 23-04-05, 01:23 PM   #18
Stig
................but seeing as summer is here i think ill be on a bit more now
It is must have missed it
new straight bars on my sv naked jans1971 Bikes - Talk & Issues 13 27-09-08 03:21 AM
Flat bars? Jase22 SV Talk, Tuning & Tweaking 4 22-04-07 03:24 PM
SV 1000s and flat bars samssv SV Talk, Tuning & Tweaking 1 23-09-06 08:00 AM
Flat Bars TSM SV Talk, Tuning & Tweaking 5 05-01-06 08:57 PM
Flat bars on my SVS. BURNER SV Talk, Tuning & Tweaking 9 12-12-04 10:40 PM
