Old 08-08-10, 09:43 PM   #1
SVforvictory
Default How do you clean out an empty fuel tank?
My 2000 SV650S is poorly; it idles nicely but as soon as you increase the revs (in gear or in neutral) it misfires and eventually cuts out.
Thinking some water might have got into the tank I drained it today. I think there might be a tiny bit of water in there, but I'm more concerned by all of the rusty dirt that came out too. There was also quite a collection of the stuff around the fuel tap.
I did a search and saw some people recommended putting a bit of fuel back in, swishing it about, pouring it out and repeating until the fuel's clear. Is this the best way or is anything else more effective?
Old 08-08-10, 09:54 PM   #2
Spikenipple
Spikenipple's Avatar
Default Re: How do you clean out an empty fuel tank?
Yeah chuck a litre or two of petrol in there, give it a good shake about and that should do the trick.
Had: K7 SV650S in Candy Sonoma Red
Now: MT-09
My old SV
South & West Surfer
Spikenipple is offline   Reply With Quote
Old 08-08-10, 09:54 PM   #3
Start from the top!
One of the old threads has been quoted recently in a thread about tanks look back a couple of days
Is the fuel line not kinked or trapped under the tank?
Old 08-08-10, 10:00 PM   #4
Razor
drain the carb bowls too
Old 08-08-10, 10:04 PM   #5
reddex doesn't go amis neither got sum 4 nowt and works a treat
Old 09-08-10, 10:02 PM   #6
SVforvictory
Thanks for the replies guys, I'll give it a good clean this weekend; hopefully it'll start running a bit better.
Old 09-08-10, 10:38 PM   #7
SIII
SIII's Avatar
To clean a petrol tank properly they should be steam cleaned. If the tank has had water in and therefore gone rusty, you really need to put rust eater in, let that cure, rinse with petrol, allow to dry thourghly, then put Petrol tank sealer in. Just google tank sealer, last stuff I got was from Frost, classic car restoration supplies. Expensive but will give a permanent seal.
SIII is offline   Reply With Quote
Old 10-09-10, 08:38 PM   #8
Darth Do'Urden
In relation to this issue of water in the tank....
I'm fairly certain I've gotten enough rain water in my fuel system that my bike isn't running now. It'll start, idle extremely low (1k RPM), and cut out if I rev to more than 1500 RPM. Anyone know of a tutorial, walkthrough, How-To, etc. for draining the tank and carbs?
I've got a 2000 SV650N.
Old 11-09-10, 09:05 AM   #9
punyXpress
punyXpress's Avatar
Tank off.
Pint of diesel in.
Handful of old nuts in.
Shake tank like mad until tired.
Repeat shaking.
Drain filthy diesel out.
Rinse with more diesel until clear.
THEN apply sealant.
Tank back on. Fill with PETROL.
Ride until the cows come home.
ALSO : check filler drain isn't rusted through - there's a few threads on how to fix.
Now: Street Triple R
SV Fuel Tank 5hort5 Stuff Wanted 5 22-12-09 12:42 AM
fuel tank mikey devon Stuff Wanted 2 05-04-09 10:28 AM
Coolant tank looks empty but radiator full to brim? GooseSVSK2 SV Talk, Tuning & Tweaking 11 07-03-09 01:47 PM
247.2 miles and the tank is not yet empty Kinvig Bikes - Talk & Issues 12 10-03-08 10:16 PM
the sv fuel tank kwak zzr SV Talk, Tuning & Tweaking 15 23-10-07 04:21 PM
