24-07-14, 08:24 PM | #1 |
Pointy reg/rec wires getting hot
Hi there,
I've been lurking on these pages for a while now in a bid to keep my lads bike on the road, so sorry that this is my first post, and I'm asking for help! It's an '03 pointy and I've just put a third reg/rec in it. The previous 2 were 2nd hand so just thought that they've passed their prime. After I fitted the 2nd one I had the wiring checked by a mechanic and all the readings were spot on. Since then I've found that the 4 wires coming out of the rec (2 black/red, 2 black/white) are getting very hot after a couple of minutes, which have probably cooked the previous units. After trawling through these boards, I have checked the connector, the green ignition barrel plug and run a couple of extra earths to the battery and frame from the rec but no difference. All I can think now is buy another loom or get an electrician in. Any ideas please? Thanks.... Andy |
24-07-14, 08:45 PM | #2 |
How hot is hot? A bit warmer than you might expect is normal, but if they're properly hot the likely cause is the female connectors are dirty or not clamping the male part correctly - the resulting resistance causes heat. Clean everything carefully, and close the female connectors up a bit so they effectively hold the make part firmly.
26-07-14, 09:16 PM | #3 |
Re: Pointy reg/rec wires getting hot
Sorry for the late reply. They get too hot to touch eventually. I have bought a new 4-way socket from Halfords as the original looks impossible to clean properly. Both black/white wires look burnt. I would have had it done tonight if I could find my flux to solder the wire extensions in.
The moral of the day is: don't tidy your garage, you won't find anything ever again ;0) Last edited by Andydrz; 28-07-14 at 12:11 PM. |
28-07-14, 12:11 PM | #4 |
New connector block fitted last night, wires no longer getting hot, SUCCESS!
But... I tidied up the wiring and re-routed the extra wire from the rectifier to the positive terminal on the battery, but didn't remove the earth wire before doing so. A spark or two but nothing major. Went to take the bike out for a test run and now all I get is the neutral light on and nothing else. Have I buggered up the starter solenoid by being a bit lazy? Battery voltage is good and all fuses ok. This bike is beginning to do my head in :0/ Last edited by Andydrz; 28-07-14 at 12:13 PM. |
28-07-14, 03:30 PM | #5 |
Probably blown the main fuse by the starter solenoid..... is separate from other fuses.
Located under r/h (o/s) seat infill |
28-07-14, 11:29 PM | #6 |
It's a pointy, I thought the 30 amp fuse (checked ok) was under the riders seat or is there another?
29-07-14, 05:59 AM | #7 |
Yeah that's the one I was on about..... derr sorry yes under the seat (its been a while since I had one)
29-07-14, 06:41 AM | #8 |
What "extra wire from the rectifier"?
30-07-14, 11:07 PM | #9 |
The rectifier I bought from Wemoto has an extra wire straight to the positive on the battery.
I've mucked around with it a bit today but no joy. Swapped the starter solenoid and fitted a spare ecu, but no change. Sometimes the neutral light stays on after the ignition switch is turned off. I also noticed when I reconnected the battery and turned the ignition on, the rev counter went to 7k and then back down again? |
08-08-14, 10:08 PM | #10 |
Problem fixed!
The main earth lead connection under the rear of the fuel tank was dodgy, and I must of disturbed it when routing the extra wire to the battery. |
Thread Tools | |
Do I need these wires? Curvy. | bubbleo | SV Talk, Tuning & Tweaking | 11 | 13-03-14 05:06 AM |
Extending Wires In A HID Kit? | CAhmroiss | Bikes - Talk & Issues | 0 | 05-01-14 09:20 PM |
Strange wires??? | krhall | Bikes - Talk & Issues | 5 | 16-03-07 12:58 PM |
2nd/3rd wires | andy owen | SV Talk, Tuning & Tweaking | 1 | 29-01-06 05:08 PM |
chafing wires | philb | SV Talk, Tuning & Tweaking | 3 | 13-06-05 06:34 AM |
