Hi folks.
The bike went into the garage for a service last week and I asked them to look at the brakes cos they're feeling really rubbish at the moment. He said he gave them a clean so the cylinders were moving freely. Fair enough, I know they get a bit sticky. The thing is, the front brake reservoir is just (and I mean just) above the minimum line in the viewing window. I did ask if he filled it, but he said it didn't need it. Was he talking crap? Are the brakes less effective when the level is low? So, if I'm going to fill it myself (bl00dy mechanics!), do I just unscrew the top of the reservoir, fill it then screw it back on, or do I have to bleed the system or anything like that? Cheers for any advice! |
No the brakes aren't less effective, if the level is between the two marks - upper and lower - it's fine.
Depending on the wear of your brake pads, it may not be a good move to top up the fluid level, if the pads have significant wear, then the fluid level will drop as the pistons are further out of the cylinders in the caliper, and as such the fluid must be displaced to the lower part of the system, if you were to top up the fluid in such a situation, when you fitted new brake pads you may have to take some of the fluid out of the system in order to allow the pistons to return into the calipers.
"IF" you do want to top up though, all you have to do is unscrew the lid, remove the rubber bellows, chuck in a bit of fluid, replace bellows, replace lid.
No need to bleed. AS Mr Squid says though, if it is between the lines you are fine. |
You can top it up no problem just fill it between the upper and lower lines
,The brakes are no less effective when low but it is advisable to keep the fluid between the two lines , gradually when your front pads wear the fluid will go down a very little amount over time , You can fill it easily yourself you DONT need to bleed your system. Just undo the two screws on the top of the reservoir (im guessing by your name you have the naked model), remover the diaphragm plate and diaphragm (usually comes off all in one piece) Top up using new fluid to the ridge alond the inside of the front wall of the reservoir. (dont overfill) seat the rubber diaphragm back in place and install the plate and cover and put the two screw back in. dont get brake fluid on your paint work else it will eat into it like paint stripper , place a cloth over paint work etc to protect it . hope this helps . CSIMMO |
There were no replys to the equestion when i wrote this
![]() i cant belive its taken me 13 mins to write this |
Thanks guys.
The Sick Man
Are you sure its low, or just because the rubber black seal inside looks like its pushed down?
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
Thread Tools | |
Brake Bleed nipple/Mityvac/Brake Fluid query | Ceri JC | SV Talk, Tuning & Tweaking | 15 | 20-01-09 02:04 PM |
What Brake Fluid... | DoubleD | SV Talk, Tuning & Tweaking | 10 | 03-03-08 11:21 AM |
Dot 5.1 brake fluid | DanF | SV Talk, Tuning & Tweaking | 2 | 09-04-07 03:15 PM |
Brake Fluid & Oil | krhall | Bikes - Talk & Issues | 6 | 20-12-06 12:58 AM |
Brake fluid | Trix | SV Talk, Tuning & Tweaking | 14 | 20-01-05 11:13 AM |
