23-04-05, 05:22 PM | #1 |
How long do brake hoses last?
I'm still trying to fix the front brake. It's very close but not quite right. bit spongy. The hoses are 5 years old. Should they be replaced?
On another note, if full braking power (front only) is applied on the curvy at around 30/40mph should the back start to come up, given standard calipers, hoses and pads? Andy. |
23-04-05, 05:33 PM | #2 | ||
If you were to GRAB the front brake (i.e. much harder than you would for a 'normal' emergency stop) at 30/40 mph, given the right combination of the above, then it would be enough to lift the rear - however I would not recommend using that as an indicator of whether or not your brakes are working properly!
2000 - 2004 SV650S 2004 - 2009 SV1000S 2009 - 2013 Triumph Sprint ST1050 2013 - 2016 Triumph Explorer 1200 2016 - Ducati Multistrada DVT S |
23-04-05, 05:36 PM | #3 |
Dont know if this helps but the manual says you should change the brake hoses every 4 years ...
24-04-05, 02:09 AM | #4 |
the reason hoses dont last that long is because every time you squeeze the lever the pressure inside the hose pushes against the inside of the hose forcing it to be slightly wider. all of these 'pressure pulses' cause the walls of the hose to become weaker and they expand more with each brake pump. this means that you will need more fluid per brake and therefore loose power. well not loose power but lose brakeing efficiency and will need to move the brake lever more to achieve the same stopping force. this is what is giving you that spongey feeling you were talking about.
also, if your pads are worn down quite a bit that too will mean you will have to squeeze further on the lever. also, clean your calipers and make sure there is no crud preventing the pistons moving as this too will mean that you have to push the piston against the crud and brake pad and could make it feel spongey. to slove this problem i suggest topping up your brake fluid, cleaning your pads and caliper assembly, and upgrading to a full steel braided brake hose system, and possibly getting some EBCdouble HH brake pads, thats hat ive got and they bloody excellent hope this helps TRICK |
24-04-05, 02:10 AM | #5 |
ah crap forgot, also check you levers for play and adjustment as well, that could help you out too
TRICK |
24-04-05, 09:33 AM | #6 |
Thanks, I forgot I'm already running EBCdouble HH brake pads. Have just purchased a set of EAL lines. Roll on good brakes...
Andy. |
24-04-05, 09:37 AM | #7 | |
fantabulas
My Flickr photos |
25-04-05, 12:33 PM | #8 |
what lines?
what set up, i beleive there's all sorts of lines and kits to go for Mine's a 2001 curvy btw |
25-04-05, 01:37 PM | #9 | |
25-04-05, 07:48 PM | #10 |
What Squirrel said...
Thread Tools | |
Brake hoses. | Pam | SV Talk, Tuning & Tweaking | 13 | 09-09-08 02:55 PM |
goodridge brake hoses | kwak zzr | SV Talk, Tuning & Tweaking | 0 | 22-10-06 05:09 PM |
how long will it take 2 fit braided hoses and new pads? | kinesin | SV Talk, Tuning & Tweaking | 15 | 22-04-05 12:21 AM |
Hel Brake Hoses | kevbuck | SV Talk, Tuning & Tweaking | 23 | 22-12-04 01:31 PM |
Rear brake hoses | kevbuck | SV Talk, Tuning & Tweaking | 26 | 26-11-04 04:11 PM |
