Old 14-08-07, 03:27 PM   #1
srxaus
Question hey new clutch advice Kyoto Clutch
new member to the forum like to say hello to everyone my bike a 02 sv650s
it needs a new clutch kit i seen Kyoto Clutch plates and ebc clutch plates at wemoto.com
are they any good
plus are the any deals with clutch plate
steel plate and springs set which are available
sr
Old 14-08-07, 03:39 PM   #2
Viney
Default Re: hey new clutch advice Kyoto Clutch
I have EBC clutch plates and to date see ok. I do need a new set of steels.
Other than that, i cant be of any more help. Welcome to the site.
Old 14-08-07, 03:50 PM   #3
chazzyb
If you use WEMOTO, do check they've got them in stock before you order. Their practise is to charge your card as you place you order, not when they despatch. This happened to me when I placed my first and probably last order with them recently. No stock for a couple of weeks, as I found out when my stuff didn't turn up... Most places I buy stuff from on the 'net, stress they don't debit your card until despatch. When I pointed this out, Wemoto suggested the other places I buy stuff from can't be using secure servers! Oh yeah, that must be it!
Old 14-08-07, 04:25 PM   #4
jambo
jambo's Avatar
Well worth checking the adjustment first, Suzuki use a clutch mechanism that works rather well but can mean that your clutch slips if it's gone out of adjustment. The lever play is only 1/2 the job. Clicky below for a much-quoted response:
http://forums.sv650.org/showpost.php...94&postcount=4
Fitting Kyoto clutch plates nicky-jano SV Talk, Tuning & Tweaking 3 21-04-09 02:51 PM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
Clutch woes! Advice needed.... Kinvig SV Talk, Tuning & Tweaking 19 03-10-07 11:55 AM
Clutch advice - don't shoot me down! lukemillar SV Talk, Tuning & Tweaking 2 14-07-06 09:54 AM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
