Old 15-03-09, 12:49 AM   #91
rictus01
rictus01's Avatar
Default Re: Lunched
that's pretty much all there is even when it's got all it's bodywork on.......
Old 15-03-09, 06:28 PM   #92
rictus01
rictus01's Avatar
Default Re: Lunched
well a few bits done today but everything delayed by 168 mile ride this morning, so pretty tired, anyway......
Many thanks to Jambo for his "crane"al abilities.
Engine now back in frame.
Reg/rec refitted.
39mm FCR flatslide carb........Hmmmmmm nice
Starter power connected
Clutch linkage reconnected
Main Earth
Top engine mounting plates
and that's about it for today.
Cheers Mark.
Old 15-03-09, 06:43 PM   #93
Default Re: Lunched
oooo somebodies been busy
A productive day and riding too
Old 15-03-09, 06:50 PM   #94
rictus01
rictus01's Avatar
Default Re: Lunched
yeah was gorgeous this morning, beautiful sunny day, lovely country roads and a nice relaxed 5 hours of riding.
Oh you should like this bit Lou.....
shiney..............
( any joy with the electrics ? )
Cheers Mark.
Old 15-03-09, 08:33 PM   #95
Default Re: Lunched
ooooo shiny tooo
Do you ever sleep?? you seem to pack loads into your day!
hmmm electrics, shhhh we could have it solved this time
Old 17-03-09, 08:24 PM   #96
rictus01
rictus01's Avatar
Default Re: Lunched
Once again the beautiful weather distracted me by a bike ride , from getting on with this, spent a couple of hours this afternoon though, got the oil system buttoned up filled and spun the lump over to prime it, fitted both rads, greased the rear axle and adjusters and fitted the front sprocket, modded the rear mudguard so the ecu and relay would fit under the seat, and fitted the rear brake back.
a few more pics.
Cheers Mark.
Old 17-03-09, 11:36 PM   #97
Cazza
Default Re: Lunched
Originally Posted by Bender View Post
Is it me or do bikes look really cool when there's just an engine, forks, wheels and frame?
No. Because it inevitably means that you can't sit on it and ride it away.
I mean, just supposing, for instance, you went to look at a shiny R1 with a view to purchasing it... to find the owner standing beside the aforementioned constituent parts professing with glee: "is it me, or does this look really cool?".
Glad it's all coming together Mark.
Last edited by Cazza; 17-03-09 at 11:40 PM. Reason: Inclusion of an additional thought
Old 18-03-09, 01:01 AM   #98
rictus01
rictus01's Avatar
Default Re: Lunched
well just finished a strip and rebuild of the carb ready to fit in the morning.
Now just got to find room to fit the inforad somewhere.
Cheers Mark.
Old 19-03-09, 06:29 PM   #99
rictus01
rictus01's Avatar
Default Re: Lunched
well that was frustrating.
Wednesday saw me get most of it done to the point of firing it up, fitting the carb was a real pain as it only fits one way and if you didn't know you'd think it to big to fit (had to remove loads of bits to fit it) and the airbox was also a pain, anyway, today put the tank on, turned the key , and pressed the button.........................., turns over beautifully, lovely fat spark, timing spot on (set it one tooth before and after and then back it normal), so it looks like a fuel issue and I'll have to remove the airbox and carb in the morning( which also means stripping the subframe and evrything attacthed), Oh well, fitting the gucci bits will have to wait a while longer.
Cheers Mark.
Old 19-03-09, 06:37 PM   #100
Alpinestarhero
Default Re: Lunched
At least its turning over and you can rest safe in the knowledge you did definatly get the timing right
