Old 26-09-12, 03:29 PM   #91
Spank86
Default Re: Nero Coffee Bouncer Complaint.
Originally Posted by Stuuk1 View Post
So what happens if the OP was severely dyslexic? Does this now mean he is not entitled to write a letter of complaint? Yes computers may have spell check, however the OP may not understand the use of the spell check function.
As someone who's severely dyslexic I can highly recommend the use of a dictionary.
I bought my first one in water stones several years ago, I believe I still have it somewhere.
Old 26-09-12, 03:37 PM   #92
ClunkintheUK
I've never understood the use of a dictionary to tell you the spelling of a word. If I can't spell the word, how can I look it up?
Old 26-09-12, 03:41 PM   #93
Surely being able to speak English should at least give you a rough guess of the first few letters. Any further reading required to find it after that... well call it education.
Everyone should own a Profanisaurus too.
Old 26-09-12, 03:51 PM   #94
Biker Biggles
Biker Biggles's Avatar
Would that be some sort of dyslexic dynosaw?
Old 26-09-12, 08:14 PM   #95
Spank86
Well it doesn't help much if the word is fone but at least after a few minutes you work out it CAN'T be with an F.
Old 26-09-12, 08:53 PM   #96
NTECUK
NTECUK's Avatar
it can B in my wurld .
Old 26-09-12, 09:34 PM   #97
monkey
The letter has been removed?!
OP Did they send you a few coffee vouchers on the condition that you remove the letter from the forum?
Old 27-09-12, 06:51 AM   #98
'A rich and deeply compelling work.'
Old 27-09-12, 07:47 AM   #99
muzikill
muzikill's Avatar
The bouncer gave you a roasting and you brewed up a complaint letter. It worked.
Well done, just my beans worth. Hehe.
Old 27-09-12, 08:03 AM   #100
-Ralph-
If you had firstly the embarrassment of having authored it, then secondly the reaction to it on this thread, wouldn't you have removed it? Damn sure I would
free nero 9 for burning cds and dvds and its £40 in pc world jans1971 Idle Banter 13 06-09-09 12:07 AM
Help with Nero please DarrenSV650S Idle Banter 17 18-12-08 07:27 PM
Nero - just want to put files on a DVD! MeridiaNx Idle Banter 5 04-02-08 09:58 PM
Nero 3 Linux Baph Idle Banter 17 26-04-07 03:01 PM
IT problem using NERO 5v5 rider Idle Banter 5 19-07-06 05:18 PM
