Old 05-08-09, 09:52 PM   #101
simonDyna
Default Re: 33bhp Dyno Resutls
Not having a go at you Simon. Just being overly blunt.
Not a problem at all. It is good healthy debate.
Old 05-08-09, 09:52 PM   #102
ThEGr33k
Originally Posted by simonDyna View Post
Actually, for bike tuning, yeah. It depends on what you are using the bike for and how far you want to take its development.
So what do you gain from crank tuning?
Old 05-08-09, 09:55 PM   #103
We are not on oldskoolsuzuki.info here, or topfuellunatics.com or wherever those lads go to chat
Perhaps I should have elaborated. But unless you are into seriously well moneyed racing or prototyping, I cannot see why you would need an engine dyno. Even forced induction bikes of 250+ bhp still have stock gearboxes (as far as losses are concerned).
Old 05-08-09, 09:58 PM   #104
ThEGr33k
Simon does do some fairly serious engine tuning it appears...
Old 06-08-09, 07:21 AM   #105
joshmac
Josh you still on 33bhp?
I'm still in my restriction period, yes
Old 06-08-09, 07:25 AM   #106
ThEGr33k
Oh, why put it like that? How long you got left of your "Restriction Period"?
Old 06-08-09, 07:34 AM   #107
joshmac
'Cause I just got home from work so I'm rather tired
I'll be on full power early June next year
Old 06-08-09, 07:43 AM   #108
ThEGr33k
Same for me... Be in bed in a min. Nice 12 hour shift isnt so nice huh? Did 6 bloody shifts then I get 1 day off lol
Not so long for you to go then before the accelerator makes more change
Old 06-08-09, 08:30 AM   #109
Liam9188
Just to prove my point...
An SV 650 produces around 45ft-lbs of torque. that is then multiplied by the primary drive, whatever gear your in and final drive to give us a mechanical advantage. so that would be....
45x2.088= 93.96 for primary
Then 93.96x2.461=231.23 for first gear
and 231.23x3=693.7 for final drive, taking away say 10% for loses in transmission to make it easy is 624.33 ft-lbs of torque at the rear wheel in first.
When the same is done for top gear you end up with only 222.7ft-lbs after assumed loses.
Obviously these arn't the numbers a dyno shows us, so they must convert it somehow. Can someone fill in this gap for me? I assume it must be run in 2 gears then it can use the different figures to work out the actual amount that is on tap after all loses?
Old 06-08-09, 09:30 AM   #110
hindle8907
hindle8907's Avatar
lmao you lot have well and truly baffled my head with all this talk of .
Cranks + 555 FT-LBS - 43x2 , = Dyno - 2 to the power of 8 = WTF lol .
33bhp restriction - Dyno chart? SVeeedy Gonzales SV Talk, Tuning & Tweaking 8 04-06-10 02:32 PM
Dyno Roo Star Pennine Massive 11 04-07-09 02:32 PM
have you had yours on the dyno mac650s SV Talk, Tuning & Tweaking 11 12-12-05 02:49 PM
have you had yours on the dyno imaleon Bikes - Talk & Issues 10 06-01-70 05:29 AM
