Old 02-12-08, 08:02 PM   #121
BBadger
Default Re: Bent Banana - The SV resurrection.
I think they are trying to open up to you =P.
Fixing going well i hope??
Old 02-12-08, 08:12 PM   #122
Dave20046
Dave20046's Avatar
Lol, they should get their stubbys outta my face
Ground to a halt a tad after being bladdered all weekend and waiting on bearings....but I'm getting there Hows the bbadgermobile these days?
Old 02-12-08, 08:36 PM   #123
BBadger
Why are they there in the first place
sounds like a good compramise to driving you alchi.
It is shiny and noisey =D. when you get back on its like your first ride all over again =D, but its also soooo cold outside.
Keep up the fixingness !
Old 20-12-08, 04:50 PM   #124
Dave20046
Dave20046's Avatar
Just been spannering about....think my luck might be running out guys - my cylinder head cover is bent & actually cracked at the front and has a few fractures at the back and I'm guessing these aren't easy to get hold of. What sort of pressure are they under would it be possible to hammer it straight and use a bit of chemical metal on the mofo?
Also there seems to be a lot of suspicious drips of oil about I'm a bit worried the engine's blown in other places but guess I can't fund out until it's running. Behind the gear change and under a bulge (clutch cover?) above the oil level viewer look particularly suspect.
Old 20-12-08, 04:52 PM   #125
Dave20046
Dave20046's Avatar
Anyway for now I'm going to check/adjust my tappet clearance (got a manual) any tips? And does anyone know what size that big allan key thing is on the casing to check the top dead centre (going to need to borrow a mates ot maybe use a large flathead screwy).
Old 20-12-08, 04:56 PM   #126
Do NOT use a large screwdriver, you will just annoy the next person who tries it with the proper tools. It is 10mm. Then a 17mm socket to turn the crank. The inspection port is 8mm.
The cover is not a structural part. as such.
Take the rear one off, drill and tap the hole for the rad bolt. Take the knackered front one and chemical metal it.
Or alternatively give me some beer vouchers for a replacement Only ones I have are black.
Old 20-12-08, 05:12 PM   #127
Dave20046
Dave20046's Avatar
Cheers chris, why should I swap the front one (weaker one) to the back? is it absolutely necessary or could I just bash and repair the front one and put it back on. Eitherway I have a feeling there may just be some beer vouchers comin your way My engine's black anyway. It is pretty bent at the front so probably wouldn't seal right- I'll get a piccy.
Old 20-12-08, 05:15 PM   #128
The back one is not loaded by a radiator rattling about on it, so doesn't need the strength.
Old 20-12-08, 05:18 PM   #129
Dangerous Dave
A bit late but I will confirm that is correct, as you would expect from Chris.
Thoroughly clean the engine up with degreaser and then check it daily for any signs of where the leak is coming from. Someone on here also suggests using talcum powder to locate a leak.
Old 20-12-08, 05:22 PM   #130
Yup that shows it up really well. Clutch cover is usual suspect in that area. Easy fix.
Bent rim! phil24_7 Bikes - Talk & Issues 18 01-11-07 02:51 PM
The worlds straightest banana gazman Photos 15 19-08-07 07:21 PM
Geostationary banana over texas philipMac Idle Banter 5 01-02-07 10:21 AM
2000 W reg naked tweaked banana for sale Sloth For Sale - SV's and SV related items 0 25-06-06 12:28 AM
Photos of my new VFR Banana... chutz Photos 28 03-09-05 01:52 PM
