Racing and Paddock Chat The latest news, talk, and gossip from the world of bike racing, you can also discuss track days here too.
Old 21-06-10, 08:44 PM   #121
Tim in Belgium
Default Re: No Budget Cup - That's Numberwang! Racing
Hole in rear bodywork:
Crack and hole fibre glass repair setting:
All fixed before filler. Aesthetic quality is high on my list of requirements :
Sticking pistons extended for cleaning (although I'd run out of brake cleaner ) :
Replacement cheap chav lever:
Heavy duty replacement alternator cover fitted:
Slowly getting there.
Old 22-06-10, 09:42 AM   #122
Stu
Trinity
Stu's Avatar
Brake cleaner is apparently not for cleaning pistons
http://forums.sv650.org/showpost.php...31&postcount=4
and
http://forums.sv650.org/showpost.php...35&postcount=6
Old 22-06-10, 10:41 AM   #123
When you extend pistons, just take pads out (20 seconds on that!) and pump them out before you take the calipers off the forks.
Old 22-06-10, 10:54 AM   #124
Berlin
Now that crank case cover REALLY makes it look like a racer! It'll be MUCH faster now!
C
Old 22-06-10, 11:34 AM   #125
punyXpress
punyXpress's Avatar
And a few scrapes with a barsteward file would make the rider look wellard!
Now: Street Triple R
Old 22-06-10, 01:43 PM   #126
jambo
jambo's Avatar
Having done a fair few miles/years with my ZX6R with both 4 and 6 pot tociko's I genuinely recommend stripping the calipers entirely and rebuilding them. I can do a set in an hour now and no short-cut has ever really worked for me.
Jambo
P.S. if any of the pistons are past their best, PM me, I can have a look in the garage to see if I have a spare or 2.
Old 22-06-10, 03:49 PM   #127
Tim in Belgium
The pads are out, I jammed some loose ones in to stop the bottom four moving and get the top two to extend. There's a bit of crud on them but no real sign of corrosion/wear.
Old 22-06-10, 04:48 PM   #128
Yeah but if you've got the disc held in the middle then they all automatically extend to their max point for best cleaning. Dead easy.
Old 22-06-10, 05:33 PM   #129
Stu
Trinity
Stu's Avatar
And then how do you get the caliper off the disc without scratching the disk to f***?
Old 22-06-10, 05:36 PM   #130
It doesn't scratch the discs.
No budget Cup Stu Racing and Paddock Chat 31 03-06-10 09:51 PM
Budget metalmonkey Idle Banter 26 24-03-10 11:53 PM
£6000 budget - what did I buy? nakedblue650 Bikes - Talk & Issues 48 27-03-09 11:03 AM
Convenience on a budget SV PILOT Riding Gear 19 12-05-08 12:26 PM
The Budget - how will it affect you the_lone_wolf Idle Banter 40 13-03-08 04:36 PM
