#131 |
cos there must be some air in there somewhere.....if you have no leaks thats all it can be.
#132 | |
It couldn't be the fluid could it?
#133 | |
If you are still getting fluid then its leaking. Most obvious places are normally the bleed nipples themselves, the cone at the base of each nipple is the seal, not the thread. Check that these cones are clean and smooth, no rust or damage to the surface. All other locations should have copper washers and shouldnt leak if they are tightened properly. Give it a good once over clean and get everything dry before you start. Failing that shove it in a van and bring it over, I'll get em working for you. |
#134 |
I haven't read all the pages of replies for obvious reasons but...
Have you tried bleeding the brake banjos? The big bolts that connect the brake line to the reservior and the caliper? What you need to do is the same method as the bleeding nipple, get someone to slowly squeeze the brake lever in while you undo the banjo and untill liquid comes out then tighten it back up before the brake lever reaches the handle. Make sure that it is tightened back up before the brake reaches the handle though otherwise you will just be letting air into the system. I find normally the first couple of times I do this when bleeding brakes I just get a tiny bit of fluid and mostly air spitting out so you need to do it untill all you get is fluid coming out when you undo it. |
#135 | |
#136 |
I really cba reading through all the replies to see if it was suggested! Lol! Got to page 4 or 5 and was like I'm just going to post.
#137 | |
Cheers for the offer Flymo I haven't any access to a van anymore though, I've been dropped off works insurance and being 18 I can't rent or get insured for a day on a mates ![]()
#138 |
lol don't blame you
#139 |
I dont honestly see the need to bleed the top banjos especially with a naked and its combined res/master cylinder. As long as the bike is on its side stand and the bars turned to the right it will be fine.
#140 |
Why turn bars to the right? Surely that makes M/C stick up in the air a tad? I put on side stand with bars turned left, makes end of M/C point down slightly so any air move up towards reservoir?
"Your Viffer sounds like it is raising hell! Spot on." - Witchery 17/4/08 ![]() Snow Plough Appreciation Society - Member #3 ![]() Last edited by Luckypants; 17-03-09 at 01:53 PM. Reason: left and right confused! |
Bleeding Brakes - Again | HopefullySoon | SV Talk, Tuning & Tweaking | 2 | 28-08-07 09:13 AM |
Bleeding Brakes (Bleeding Kits) | 21QUEST | SV Talk, Tuning & Tweaking | 8 | 20-06-06 05:31 PM |
Bleeding Brakes | sweepdoggydog | SV Talk, Tuning & Tweaking | 9 | 08-06-06 07:07 AM |
Bleeding brakes | Samurai | SV Talk, Tuning & Tweaking | 6 | 06-06-06 05:17 PM |
Bleeding Brakes | Moo | SV Talk, Tuning & Tweaking | 9 | 21-01-06 07:59 PM |
