#1411 |
No, there is a button to switch from manual to AE mode but that is about it. I took the mount off. The lens feels as if there is nothing attached to operate the aperture.
Flickr https://www.flickr.com/photos/39887875@N06/ Last edited by Kenzie; 09-07-16 at 01:45 PM. |
#1412 |
It sounds like something's missing. I haven't got any Canons but on all the lenses I have, there's some kind of tab and mechanism in the mount that stops down the lens.
#1413 |
Oily blades. Who knows if I can get it back together though! Had I known better I could have just unscrewed the rear element and swabbed the blades. Live and learn.
Flickr https://www.flickr.com/photos/39887875@N06/ Last edited by Kenzie; 09-07-16 at 04:04 PM. |
#1414 |
I'd have said oily blades too, the spring on them isn't very stiff.
Yoko: http://www.gumtree.com/p/video-camer...1.9/1177670312 these are supposed to be a good camera, a well-kept secret, and Seikosha shutters are said to be very good and very quiet |
#1415 |
Will try to reassemble but it's not looking good.
#1416 |
You need to take more pictures when you're tearing them down!
#1417 |
Its not so much that, I cant get the lens body back into the focus ring and lower housing. Only found one worth picking up, a Beirette V with case for £2
![]() Hey Yokohama, just tested my A11 flash on your XA3 and it won't fire. I think that's the only thing wrong with it. Unless I'm just being an idiot. Put a bid on this as they are quite rare 331901981444 Just bought this 112052771654 hoping that its a case of needing to set the shutter before pressing the release button!
Flickr https://www.flickr.com/photos/39887875@N06/ Last edited by Kenzie; 10-07-16 at 07:18 PM. |
#1418 |
The Beirette looks in good condition. Can't complain for a couple of quid with a case.
It's no big deal if the XA3 flash doesn't work. I don't use flash very often; I keep them turned off all the time on the mobile and digital camera. |
#1419 |
I thought so too. It had a horrible white sticker above the lens but peeled it off and removed the gunk with lighter fluid.
Sent from my Xperia T
Flickr https://www.flickr.com/photos/39887875@N06/ Last edited by Kenzie; 11-07-16 at 08:26 AM. |
#1420 |
A slight downer with the Tamron Adaptalls. Because of the adapter mount, that nifty little Minolta window which shows aperture doesn't work.
