Old 15-09-14, 09:07 AM   #141
atassiedevil
Default Re: What have you tinkered with today?
Had the carbs off the EN500 to get it sorted. One stuck float needle, and as usual both float bowl o rings are perished. New ones on the way. Once it's done, the Mrs is doing her DAS. Probably next month.
Old 15-09-14, 12:04 PM   #142
Andy_J
Modified my airbox on the sv650 k5 that I am rebuilding slowly. Did the TPS mod. Got more parts coming this week. I know what I want it to look like and it is getting there. Slowly.
Old 16-09-14, 06:21 PM   #143
New seals in one rear caliper & reassembled.
The other spare caliper joining bolts refuse to budge, so Plusgaz treatment for them
Old 17-09-14, 11:32 AM   #144
leebex
Done the same for my wifes sv recently.nice little job.
Old 17-09-14, 11:36 AM   #145
Caliper refitted & brake bled. A happier caliper now
Old 17-09-14, 03:18 PM   #146
Ch00
Ch00's Avatar
Today I have fitted a new screen, fitted a new hugger as the old one was about to fall off and fitted a 12v lead into the top box.
Ch00 is offline   Reply With Quote
Old 18-09-14, 10:28 AM   #147
atassiedevil
Fixed water leak and wiring issue on the VF1000. All ready to go
Old 18-09-14, 12:18 PM   #148
Littlepeahead
Littlepeahead's Avatar
I started a ten week motorcycle maintenance evening course last night at Hackney College with CMSD2. I'm basically clueless and fed up with paying the BMW dealer to do everything so when he suggested it I thought it was a good idea.
Ideally I would take my own bike along each week but the ride from Chelmsford to Lord's then back to Hackney then home will probably be a bit much in the middle of November after a long day at work so instead I'm planning on taking Chris's Tiger to bits each week, and if he's very lucky I might put it back together again.
Old 18-09-14, 12:52 PM   #149
NTECUK
NTECUK's Avatar
After visiting mum at the hospital and ridding home in the dark. A H4 night breaker in the zx6r's headlight
Old 18-09-14, 05:24 PM   #150
admin
John T
admin's Avatar
Default Re: Re: What have you tinkered with today?
A great idea. I had a friend who knew his bikes and I learnt a lot from him. Once you know the basics you'll get the confidence to try bigger jobs. It's very satisfying too.
sent via Pony Express
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
