#1691 |
#1692 |
Got a DID chain tool so I could fit my new chain and sprockets. Good bit of kit!
To remove the old one I ground off the pin heads then pushed them out using the tool ![]() ![]() ![]() It came out very easily ![]() Mounted up the new sprockets ![]() ![]() Because I was getting new sprocket sizes I wasn't sure how many links to get, so played it safe with a couple extra. Obviously I didn't want to grind the rivits and cover the new chain with crap, so I just went for it with the chain tool. The pin popped out very easily! ![]() ![]() Crimped on the left ![]() All done ![]() |
#1693 |
Removed the pillion strap on the spare pillion seat that the seller gave me with the GSXR and fitted Kriega straps instead. Very securely clamped in there. Nowhere to attach the rear two though, so they'll have to be looped together under the seat without fixing in place.
Also cut a half inch off the coolant hose that was causing the leak and refitted. Luckily it's just long enough, so I don't have to shell out on a new set of hoses. ![]()
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
#1694 | |
#1695 |
Today ive washed the car, even though it doesn't move much due to my Mrs being furloughed ... we bought a new Corsa in March and so far it's done 274 miles !!!
I gave the back a clean at the same time ![]() ![]() Sent from my SM-G960F using Tapatalk |
#1696 |
New ktech fork springs installed (new oil as well of course). Really pleased with the result - only wish I had a decent rear shock to match.
- K9 SV650S: Hel brake lines, carbon end can - SZR660: The project... - K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now) |
#1697 |
The new battery optimiser was waiting for me when I got home so I connected the permanent leads and ran them through to under the seat cowl, and while I was messing around I decided to fit the heated grips that I'd salvaged from the ER before I traded it in.
I'm not 100% happy with how the control panel is mounted so I might have to fabricate something neater ![]() ![]() Sent from my SM-G960F using Tapatalk |
#1698 |
One of the mounts they provide has holes that match up with the clutch lever clamp bolts. You can fix it to that and the mount bends as you tighten the bolts so it sits flush against the clutch lever clamp.
#1699 | |
It's a set I took of a bike, not a set I bought new ![]() ![]() Sent from my SM-G960F using Tapatalk |
#1700 |
Yep. Mine came with that in the box. The bracket bends as you tighten down the bolts to form a curve flush to the clutch clamp. I'll try to take a pic of it on my VFR tomorrow after work.
