Old 12-05-20, 01:22 PM   #1701
shiftin_gear98
shiftin_gear98's Avatar
Default Re: What have you tinkered with today?
I too had mine on the clutch bolt. Much less intrusive.
Also much easier to operate with your clutch hand whilst riding instead of throttle hand.
If you have any sheet metal kicking around they are easy to knock up. Mine needed replacing, so I knocked one up out of a section of cable trunking.
Currently driving a Corsa....
Old 12-05-20, 02:06 PM   #1702
Adam Ef
Adam Ef's Avatar
Not a great photo but...
Past:
Old 13-05-20, 01:51 PM   #1703
admin
John T
admin's Avatar
Fitted a voltmeter to the VFR. This is quite a common mod given the charging issues that a lot of these bikes suffer from.
Sent from my Nexus 7 using Tapatalk
Old 13-05-20, 03:32 PM   #1704
Adam Ef
Adam Ef's Avatar
What are you going to fit on the other side John? A USB port maybe?
Past:
Old 13-05-20, 03:41 PM   #1705
Adam Ef
Adam Ef's Avatar
Air filter replaced on the GSXR. Not sure how old the other one was but keen to get anything unkown swapped out.
Also took the front end apart to fit Variobars I'd got second hand. Went to adjust the bars and found one of the bolts totally seized and bolt corners mashed too much for a socket to engage with. So, all taken off again and back together as it was. A real pain and waste of time and now the seller is being a d**k on eBay and refusing to send a return postage label and hasn't got a clue how to navigate eBay (as mentioned on "gripe" thread) .. I'm sure he actually has and is just trying to make it as difficult as possible and hold on to the refund money as long as possible.
So bars will stay the same for now and I'll just have to do some more Joe Wicks PE with the kids to strengthen my core
Past:
Old 13-05-20, 03:55 PM   #1706
admin
John T
admin's Avatar
Probably. I've already got one on the right-hand bar. I've since filled that hole with the lid off a 35mm film cannister. I bought the meter ages ago, it's waterproof for marine use. It's connect via a relay.
Old 17-05-20, 06:50 PM   #1707
aj76
So a reasonably productive weekend with little man's push bike rebuild and if dad (me) wasnt such a Muppet it would have been finished
Didn't realise the front derailluer I ordered was top pull and not bottom pull
Front forks removed, stripped, primed and painted and refitted
Rear swing arm pivot cleaned and greased.
Handle bars stripped, sprayed and refitted,
New brake levers and gear shifters fitted.
New v brakes fitted front and rear, setup and adjusted with new cables
Rear derailleur new cable run and indexing set.
Front derailleur installed and new cable run.
Hopefully get the right part by next week and be able to actually get the SV out next Sunday for a short ride
Sent from my Pixel 3 using Tapatalk
aj76 is offline   Reply With Quote
Old 21-05-20, 05:03 PM   #1708
Grant66
Grant66's Avatar
New LED indicators, all the way from ameriki in under a week.
Think I've run out of cheap (ish) changes now. Hopefully the cost of the more expensive ones will put me off buying anything else.
Sent from an S20 using Tapatalk with that kin cr4p blocked
Formerly known as Gajjii
Previous Bikes: Red Sk1 Curvy, Red MT-07.
Current Bike: Black MT-09.
Grant66 is offline   Reply With Quote
Old 23-05-20, 07:33 AM   #1709
dirtydog
Knob faced knobster
dirtydog's Avatar
Not done any bike tinkering but have spent about £300 this week on bike stuff so that ive got everything I need ready to tinker.
I'm ditching the clipons and doing a bar conversion.
2001 SV650 in shimmerin green, Not broken anymore
Old 25-05-20, 02:17 PM   #1710
Sean_Morgan
What have I tinkered with today ?
Nothing at all, I've been out collecting nods and bugs
Sent from my SM-G960F using Tapatalk
Sean_Morgan is offline   Reply With Quote
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
