#11 |
Good. Then there's no actual fault with the bike.
Start with the simple things: - Is it in gear, with the sidestand down? (green light is a good indicator but isn't fool-proof). - Kill switch, flick it a couple of times. That done, when you pull the clutch in & hit the starter, what exactly happens? Does the engine attempt to turn over, but not catch? Do you hear a series of rapid clicking from the seat of the bike? Do the lights dim? Do the lights go out almost completely? |
#12 |
bike started no FI showing so hope it might have been the tip over switch when i removed the battery tray to do the shock change will check again tomorrow and hope all is ok then wait for for the roads to dry so i can check out the shock, thanks for all your help
#13 |
#14 |
#15 |
cheers at least now when i sit on the bike there is a bit of movement in the rear end now so should be able to stay in the seat on any bumps just got to set the sag and that will be me happy thanks again for your time
#16 |
#17 |
But 7 flips will confuse it so much, that it will think it is an australian import.
#18 | ||
#19 |
well ive only now gotten around to doing this, flipped the kill switch, dosent change anything, still FI error.
had alook to see to set the bike into dealer mode, but my 2 empty points are not next to each other like in your diagram, one is in the middle left and the other on the bottom right. do I just use the 2 empty one anyway? also, I cant seem to find the tip over switch, where abouts by the battery tray is it? any pics? cheers |
#20 |
ok, found the tip over switch, and it is fine, pointing the right way up and looks secure
The Applecross Dash | Wordsmith | SV Ecosse | 26 | 10-05-08 07:15 AM |
The Dash | Ward8124 | East Anglian Revolution | 0 | 20-08-07 06:28 PM |
how to get radio out of car dash? | weazelz | Idle Banter | 18 | 09-07-07 02:58 PM |
Flashing FI on dash? | creamerybutter | SV Talk, Tuning & Tweaking | 9 | 04-07-06 08:06 AM |
SV 99-02 dash lights | sprocket | SV Talk, Tuning & Tweaking | 5 | 31-08-05 12:38 PM |
