#11 |
I've always fully charged a battery with my Optimate IIISP before fitting it, whether I need to put the acid in or not. Thas what most batterys say to do.... plus it doesn't do any harm and takes hardly any time to do.
#12 |
hmmm my battery never said anything about charging it beforehand? hence i just filled it, left it to settle, put it in, and off i went
#13 |
Ah well, when you're 200 miles from home you'd just connect it and go, just like I did
#14 | |
i emailed accumate, the company that sells optimates and accumates, and this was the response i got
#15 | ||
#16 |
mine must not have needed a precharge then, after all my power woes, the new'un started fine
#17 |
I just changed my battery and it said to just fill it, leave for at least 30 mins then use it. I fitted it and started the bike straight away.
#18 |
Go ahead and charge it up, your Optimate will do all the work and look after it! Good piece of kit!
#19 |
Lead-acid batteries like to be kept as near fully charged as possible.
If you leave one flat for any length of time it will die. Fully charging will do it good, and it'll make you feel better. ![]()
battery is going flat all the time. | graemeclark | Bikes - Talk & Issues | 8 | 27-12-08 01:40 PM |
battery wont hold charge | taffo | SV Talk, Tuning & Tweaking | 14 | 29-12-07 08:04 PM |
Do I need to charge my battery? | M65 | SV Talk, Tuning & Tweaking | 6 | 15-07-05 11:20 AM |
New Battery Time? | snoopy | SV Talk, Tuning & Tweaking | 4 | 17-04-05 02:51 PM |
Battery/Starting problem - new battery hasnt fixed it! | Aaron | SV Talk, Tuning & Tweaking | 13 | 24-01-05 05:21 PM |
