Old 01-12-07, 06:34 AM   #11
zadar
Default Re: forks
Originally Posted by Robw#70 View Post
Fitting SV1000 front of a carby is the same as late GSXR, ie different top bearing and the lockstops wont work or the steering lock.
They're not that great and pretty long, better off going for GSXR rwu or usd
yep,not great choice of forks.
gsxr600/750 is the way to go.depending on your weight you can choose year that has correct springs.
Old 01-12-07, 07:56 AM   #12
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: forks
Originally Posted by jon8oy View Post
Thanks
only im wanting to fit the 4 pot brakes to improve the braking but need brackets to make them fit iv posted a wanted thread for said brackets but to no avail need help.
cheers
Have a look here for aome adapter plates to fit Gixxer/SVthou brakes to a standard SV650. They are being made at the moment and should be ready by the end of next week.
http://forums.sv650.org/showthread.php?t=99451
2011 Speed Triple 1050
Old 01-12-07, 10:11 AM   #13
jon8oy
Default Re: forks
Cheers DD
Looks a pretty good set up, reading on though peeps are saying to change the master cylinder do i need to look down that path also to get any real benefit from the brakes (got braided lines already to go on also)
john
Old 01-12-07, 12:41 PM   #14
ThEGr33k
Default Re: forks
The master cylinder should be adaquate from the origional brakes...
Old 01-12-07, 02:12 PM   #15
Default Re: forks
Yep, it will be. I'd change it anyway, since it's kind of a shame to settle for adequate with this sort of upgrade, but it'll work.
Old 01-12-07, 02:18 PM   #16
jon8oy
Default Re: forks
cheers to both reply's on upgrade in brakes
issue relating to the master cylinder whats the best upgrade to standard while im getting all sorted may as well go for that also
Old 01-12-07, 02:30 PM   #17
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: forks
Indeed it will be perfectly ok to use the original master cylinder, I'm still using the original with braided hoses
Northy you change most things though
Old 01-12-07, 02:47 PM   #18
Default Re: forks
Indeed I do But, this one does kind of make sense. Certainly not neccesary.
Old 01-12-07, 07:31 PM   #19
Stu
Trinity
Stu's Avatar
Default Re: forks
I don't think I would want my brakes any stronger.
(Gsxr front end original M/C)
If you get the adapter plates I don't think the MC would be the limiting factor so see what it's like first.
Old 01-12-07, 07:55 PM   #20
Default Re: forks
It's not about power, it's about how you can use it... I like the R6 master cylinder, frinstance, which has less power per mm of travel but delivers it much better.
USD GSXR1000 k1 forks | standed forks - curvy Nicky S SV Talk, Tuning & Tweaking 113 07-09-09 01:12 PM
R1 forks yorkie_chris SV Talk, Tuning & Tweaking 4 15-11-07 07:10 PM
Forks markmoto SV Talk, Tuning & Tweaking 7 13-07-07 12:22 PM
New forks ?? Stig Photos 12 02-01-06 08:39 PM
Forks Viney SV Talk, Tuning & Tweaking 11 14-03-05 08:52 AM
