Old 17-12-07, 06:36 PM   #11
andyb
Default Re: K5 SVS No ignition
If you do want them wired into the ignition relay I'm quite happy to do it for you Fizz/Liz if you need any help (which I very much doubt! )
Old 17-12-07, 06:44 PM   #12
diamond
I might pick your brains Wednesday night if thats ok?
Old 17-12-07, 07:05 PM   #13
andyb
Yep no probs, it's a piece of p**s to do though! Thanks for defending my honour!!!!!!!!!
Old 18-12-07, 01:32 PM   #14
Ceri JC
I've had the same problem with my K4. Should there be a problem attaching the heated grips into a sidelight (as this will not be on if the ignition is off, unless the parking light is on anyway, in which case you'll wind up with a flat battery in any event)?
Old 18-12-07, 01:44 PM   #15
Why would you go for the sidelight?
This strategy would worry me, the wiring is designed for the low draw of the odd bulb and the horn, not grips.
I went for the main switched live, with an inline fuse.
Old 18-12-07, 02:19 PM   #16
phil24_7
I think he means use the side light as the "on" switch for the relay with the main power coming direct from the battery.
Old 18-12-07, 02:26 PM   #17
Ahhh thats a whole different kettle of fish, I'll shush
Old 18-12-07, 03:30 PM   #18
Ceri JC
Phil and yorkie Chris: Nope, being an electrical numpty, I did just put them on the sidelight in parallel. The oxford heated grips I have already have a 10 amp fuse built into the wiring them of them which I (quite possibly wrongly) assumed would blow first if there was a problem. When you say on the main switched live, where should I actually connect into the loom? TIA chaps.
Old 19-12-07, 03:26 AM   #19
phil24_7
Sorry Yorkie, I'll shush!!
Old 19-12-07, 03:28 AM   #20
phil24_7
Ceri. You can still take a feed from the lights, then connect this to the switched side of an automotive relay, then take the main power direct from the battery.
Someone will be along shortly to better explain and tell you what parts to get.
What's up with the ignition? arcdef SV Talk, Tuning & Tweaking 14 17-12-08 11:15 AM
ignition sv 650 suzanne2869 Stuff Wanted 10 05-11-07 05:10 PM
Ignition advancer? sixstring SV Talk, Tuning & Tweaking 19 22-07-06 06:39 PM
Help! Help! please, ignition problem cwachang SV Talk, Tuning & Tweaking 1 17-07-06 10:41 PM
IGNITION stewboy SV Talk, Tuning & Tweaking 14 15-01-06 01:08 PM
