Old 08-09-08, 10:18 PM   #11
embee
embee's Avatar
Default Re: Horrible knock on SV
To be honest I've always found the "rocking" test for head bearings is pretty vague, and the only really successful method is to actually adjust them. As soon as you start the adjustment you'll find out whether they are loose or not (they probably are, based on the 2 that I've seen).
Also you'll probably find the factory waved the grease tin somewhere in the vicinity of the bearings when they were assembled, so it would pay to drop the bottom yoke+stem down enough to get some grease in there, top one is easy.
Old 08-09-08, 11:00 PM   #12
ljharmitt
Can you hear the noise while the bike is stationary, or just when riding. If you can when stationary it could be the cam chain. Mine went and had to have engine rebuild so go and get it checked if its coming from the front.
Old 08-09-08, 11:14 PM   #13
plowsie
lj, read the thread mate its about knocking front ends, you know, suspension, etc lol
Old 08-09-08, 11:16 PM   #14
ljharmitt
Shush, dont make me look stupid lol. Front end of bike i thought
Old 09-09-08, 07:01 AM   #15
Dangerous Dave
Check the bearings first, then have a look for any lose cables which can cause a rattle every now and again.
Does it happen under braking or over bumps, if so then it is mostly likely the common SV problem which is easily cured with fresh fork oil. While you are at it you might as well get some springs to suit your weight too.
Horrible horrible horrible Jayneflakes Idle Banter 17 04-11-08 08:55 AM
A horrible welcome dirtsk8 Idle Banter 12 27-08-08 09:06 PM
I've been horrible and snappy! phil24_7 Idle Banter 32 04-08-08 07:39 PM
Horrible ride. ejtrent SV Talk, Tuning & Tweaking 12 16-11-07 11:37 PM
Knock, knock or paranoia? slippery SV Talk, Tuning & Tweaking 12 23-02-07 09:26 AM
