Old 31-12-07, 01:09 AM   #11
Default Re: OK, I'm a Complete and utter tw*t who can't tell the difference between brake cleaner and WD40.....
I almost burned my garage and 7 bikes down the other day.
Last winter I was working in the garage, and in the middle of something fiddly- I forget what- my fan heater got in the way so I just booted it over to the side of the garage. A couple of minutes later I went to get it, and I discovered I'd kicked it right into a plastic petrol can, which had swelled up to bursting point and had petrol and vapour squirting out under pressure around the cap, right beside the fan heater with its rubbish sparky motor "How to make a bomb"
Old 31-12-07, 02:55 AM   #12
$tevo
Has anyone else done the "spray the frozen up windscreen with de-icer only to discover minutes later that you done it with WD40" thing?
I can't be the only steaming idiot on here.
Can I?
Old 31-12-07, 12:43 PM   #13
Nope... But then, I did once go to pick up what I thought was a can of fine rubbing compound, to remove a scratch in my paint, and it turned out to be a can of black paint
Old 02-01-08, 11:38 AM   #14
jambo
jambo's Avatar
I was reading a photography magazine the other day and they had advice from the experts. One simply said:
"It is not a good idea to keep compressed air, WD40 and spray glue on the same shelf"
The feeling you must have in your gut when you've just sprayed glue onto the sensor of a professional D-SLR must be propperly nasty....
I am a complete and utter dunce. Paul the 6th Bikes - Talk & Issues 34 12-03-09 06:34 PM
brake cleaner? weazelz SV Talk, Tuning & Tweaking 7 20-03-07 11:56 PM
Utter stupidity igor SV Talk, Tuning & Tweaking 5 27-07-06 10:29 PM
Total and utter newbie here - the SV650S.... Kate SV Talk, Tuning & Tweaking 72 31-12-04 03:40 PM
