Old 10-01-08, 03:35 PM   #11
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default Re: Torque Wrench
Originally Posted by Hockeynut View Post
Damn, so the one I have only does the upper range?
tbh, i wouldn't trust a £15 torque wrench to be accurate at any part of it's range, it's about the only tool that people recommend you spend as much as you can afford...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 10-01-08, 03:38 PM   #12
Hockeynut
Damn, Dad bought it me at xmas, might feel bad telling him to return it as it's crap.
But in theory, that range should do the upper end anyway. I'll just tell him I need one that does the lower part. (Afaik Argos don't do one in tht range. )
Old 10-01-08, 03:40 PM   #13
jambo
jambo's Avatar
It looks a lot like the one I was given for free, I trust it for the heavy stuff, if a 110Nm nut is done up to 95 or 125 it'll be fine. But I would want to spend more on the lower torque values one.
Jambo
Old 10-01-08, 05:29 PM   #14
Ceri JC
The 8-60 and 40-200 Halfords pro ones are really nice. Between them, they've covered all settings I've come across so far on the SV.
Old 10-01-08, 06:23 PM   #15
Draper expert IMO.
Got one from them and it does the job, seems well put together, smooth adjustment unlike the cheapos.
It's a 3/8ths drive one so it does the lower ranges, and isn't too big and bulky to use on cam caps and such.
Old 11-01-08, 12:04 AM   #16
embee
embee's Avatar
I've checked a couple of cheaper ones in th epast and they aren't all that bad.
Top notch ones will be certified to 2 or 3% accuracy, the worst I saw was about 10% over-reading at most, generally around 5% optimistic (i.e. the scale showed a higher figure than the wrench clicked at, which is the generally safer direction).
10% might sound a lot but if it's actually 22.5Nm when it ought to be 25Nm it's not going to make any difference in most instances, unless you intend to do big-end bolts etc.
Best cheap ones are Draper IMO, you can get a 10-80Nm 3/8" drive one for around £20. As an example, look here .
Have a look here too.
Old 11-01-08, 01:46 AM   #17
That Argos one is, I think, the exact same as the Machine Mart one... It's OK, overreads a wee bit compared to the identically sized Teng one I compared it with but it's perfectly good for the job (big nuts). I have 2, I use the other one as an oversized ratchet/breaker bar.
I've got one of the Halfords ones for light work... Seems decent enough, and it's nice to use. Don't use one as an alternative for brains though.
Old 11-01-08, 02:05 AM   #18
+1 just because haynes specify a torque it doesn't mean that bolt will hold that torque.
Old 11-01-08, 04:00 AM   #19
lukemillar
Eh? How can following a the torque values in a Haynes book be a bad thing? I'd rather go by that, than a completely uninformed 'Ooo that feels about right!'
I think if people shear bolts after following specified torque settings then it is due to them over-tightening (you can still tighten with a torque wrench after it clicks) rather than the wrench being out or the book being wrong.
I know there have been genuine errors in haynes books with regards to torque settings, but generally they're pretty good. I have yet to shear a bolt anyway, following them.
Old 11-01-08, 07:08 AM   #20
the_lone_wolf
Captain Awesome
...(big nuts). I have 2...
me too
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Torque Wrench Cam_73 SV Ecosse 13 10-05-07 03:54 PM
Torque wrench Kilted Ginger SV Ecosse 6 16-11-06 10:05 PM
Torque wrench rpwoodman SV Talk, Tuning & Tweaking 7 19-04-06 12:55 PM
Which torque wrench ?? pepe SV Talk, Tuning & Tweaking 9 06-05-05 07:48 AM
Torque Wrench TSM SV Talk, Tuning & Tweaking 21 28-04-05 09:06 AM
