#11 |
There's a pretty good case for going down to a 150 on a standard SV, mind
![]() I'm not sure exactly what's involved for the injected SV- they both use the same rear wheel so it'll be doable I'm sure, but I'd need to borrow one to know for sure. Whether I can make another set... Well, that depends on whether I can make one for me ![]() I plan to do it a wee bit different to how it's done in the Billy/Plowsiemobile, which used the standard bandit spacers and bearings with an extra steel spacer. Quite inelegant and weighty, plus it'd take me forever with my hardware. So I figure on basiaclly replicating the stock setup using SV bearings and a new central spacer, plus a modified SV sprocket carrier spacer should work I think. Worth mentioning that the 2 SVs use a different axle size, if memory serves, so it could be that the whole process works out different for the injected model. I'm sure it can be done though.
#12 |
Ok,
No worries about spacers, if anything I can buy them from Twin Works, I prob won't do it for a while yet, so if you get lucky with your machining and feel like making some extra ones for a bit of dosh, then give me a shout! So I guess the last thing I need to know is what exactly needs to be machined down, you mentioned the calliper hanger...whats that exactly?? cheers |
#13 |
Well, I think Twin Works does them
![]() THe caliper hanger is the bit of ally that the caliper bolts to, sits between the swingarm and caliper. On your bike it's not so much a hanger as it goes up not down ![]()
#14 |
there is some info here
http://www.twinworksfactory.com/bbs/toast.asp |
Bandit rear wheel | Kulay | SV Talk, Tuning & Tweaking | 0 | 31-08-08 02:48 PM |
1200 Bandit FRONT wheel bearings | Blue_SV650S | SV Talk, Tuning & Tweaking | 3 | 15-02-08 09:22 AM |
Bandit 12 rear wheel | Jester666 | SV Talk, Tuning & Tweaking | 2 | 20-09-06 11:33 AM |
Bandit 12 rear wheel | BILLY | SV Talk, Tuning & Tweaking | 14 | 12-06-06 09:09 PM |
Bandit 1200 rear wheel | BILLY | SV Talk, Tuning & Tweaking | 19 | 26-03-06 12:51 AM |
