#11 |
How accurate is the speedo on the Garmin GPS units? I like the look of the Zumo 400 and the digital speedo thing is an attractive feature but only if it's accurate to within 2-3mph!
#12 |
Bike GPSs tend not only to be properly waterproof, but also made to resist knocks and particularly constant vibration better than car ones. They also tend to have bigger and brighter screens, which are much simpler to operate with gloved hands and easier to see with the sun on them.
#13 | |
Before getting a Zumo, check very carefully exactly what the spec will do, for example bluetooth, maps included, car mount included, Text-to-speech (TTS). The lower spec ones don't have various features. Best value for money has to be the higher spec, the 550 includes both cradles and European maps, b/tooth, TTS etc. Waterproofness - the Zumo unit itself is rated as IPX7, which is basically submersible, but note that the cradles aren't! You have to be a little careful making sure you keep the connector pins covered if the unit isn't in the cradle for example. The screen brightness is excellent (and is adjustable), can be set for day or night or auto switching, very good even in bright sun, and the touch screen works with gloves brilliantly. The "buttons" are automatically bigger when it's in the bike cradle than in the car cradle for example.
"Artificial Intelligence is no match for natural stupidity" Last edited by embee; 01-02-08 at 06:17 PM. |
#14 |
The GPS speed is only accurate when doing a steady straight line speed, start hooning round bends and the GPS will take a second or two to catch up each time, more likely to show a straight line speed through a set of bends. Like wise it will be inaccurate when climbing or dropping rapidly over hills. I would not trust it to replace the bikes speedo when it matters, e.g. you know there's a traffic car behind you
#15 |
It's probably most useful to mentally "recalibrate" your speedo under reliable steady state conditions, as TEC suggests above. I know that at a GPS speed of 70mph my bike speedo says 75mph for example. 30mph is not far enough out to risk doing anything over the indicated value.
#16 |
Looking like it's got to be a Zumo then but they cost a lot. Will have a look on Kelkoo.
Tom Toms and other Sat Navs | madness | Idle Banter | 7 | 02-02-09 10:21 PM |
Hydraulic clutch - advantages? | Ed | Bikes - Talk & Issues | 46 | 01-09-08 01:02 PM |
sat navs | colinsv25 | Idle Banter | 8 | 28-11-07 04:54 PM |
Advantages of V-twin over an inline four | sv650sfan | SV Talk, Tuning & Tweaking | 44 | 06-07-07 09:58 AM |
Sat Navs | pencil shavings | Bikes - Talk & Issues | 9 | 10-06-07 02:31 PM |
