Old 06-02-08, 02:42 PM   #11
chakraist
Default Re: Bike very ill
Okay, so just to clarify, it should be... remove airbox, remove radiator, remove carbs... and then remove cylinder head covers and remove cam chain tensioner, adjust and put it back in. That sound alright?
Old 06-02-08, 02:49 PM   #12
Don't need to touch the rad at all...
Airbox off, carbs off, sneak down to front CCT, check operation, lock it back, put it back in, reset it.
Rear one is a right bugger to get to, the shock and exhaust are in the way, I found it much easier to remove the rear wheel, you're still working by feel though.
Old 06-02-08, 02:54 PM   #13
chakraist
Cheers, I'll try and sort out the front one, if that doesn't work... I'll need to buy some sort of stand, haha.
Thanks
Old 06-02-08, 04:10 PM   #14
Blue_SV650S
You will need a small screwdriver to 'reset' the tensioners ... you don't technically need to take them out (and it is a right faff to get them back in if you do!!), just remove the end caps (10mm socket), slot a thin screwdriver in the hole that was revealed when you removed that bolt and wind them out (not sure if that is clockwise or anticlockwise) ... wind it out to the stop then pull the screwdriver out and see if you can hear it 'snap' back into place (picture it as a thread and a spring) ... do it a few times to make sure it is snapping back.
If it doesn't or it doesn't provide any resistance when you try and turn it, then it is fecked and you will need to take it off!!!
{bit of googlefu} ... here, use the screwdriver like this see below (note: different bike totally, but same idea ... also ignore where he has his ratchet!)
Old 06-02-08, 05:22 PM   #15
He's right you know
Have to be a short screwdriver though as there's a frame crossmember right above the tensioner.
Old 06-02-08, 09:02 PM   #16
chakraist
Thanks very much for the input guys, a real lifesaver. Will get back tomorrow.
Old 07-02-08, 01:19 PM   #17
chakraist
Okay. So I tried to fix it all today, no dice. I don't have a screwdriver short enough to put in the hole and it fits straight down. I did however, play about with a short enough screwdriver that it touched the bottom of the tensioner at a bit of an angle, and it felt very difficult to turn either anticlockwise or clockwise. Is it worth taking it out to have a mess about with it?
Old 07-02-08, 02:11 PM   #18
Blue_SV650S
Its sprung loaded, it takes a fair twist (especially where it is hard to get a good grip on the driver).
remember if you take them out you will HAVE to wind them out (and hold them out) to get them back in again ...
If they are impossible to move, not just tough, then out they come as they are proper stuck and your problem is found!
Old 07-02-08, 03:17 PM   #19
chakraist
I'll give it another go in a bit, might just take the ******* out! Thanks again for the help dude
Old 07-02-08, 03:27 PM   #20
IIRC it's clockwise to wind them out, check the service manual though as if you turned them the wrong way you could damage the camchain.
It's a right pain to get the front one back in withuot the little locking tool.
