#11 | |
Try putting a temporary link wire between the + side of the battery and the red connector on the regulator, see if the volts come up then? If this works fit the wire permenantly with a fuse link. If I can I'll post a photo of my previous bodge. |
#12 | |
The first part is true, but also if the ignition switch is playing up this could be putting a strange load on the R/R as the ignition feeds the lights and .. well everything else!! ![]() I am an advocate of the 'red lead R/R' bodge, as I am the 'Black lead R/R' bodge. (Do black first) but as you KNOW you have ignition switch problems, I think you need to sort the ignition switch first as this could be all it is ... |
#13 | |
#14 |
Looks like we got a winner I bridge the red cable from the regulator to the + terminal on the battery and the voltage increases by .4 volt and now measures 13.8 wonderful volts.
I will see if I can get a cable with a fuse casing and wire it up lets hope that this will fix the problem once and for all. I wished I had the diagnostic chart somewhat earlier it would have saved me buying a new battery and a secondhand regulator. Thanks again to all you folks helping me out I would never made it without your hep. THANK YOU |
#15 |
Its always the way right, the guy in the shop always says "yeah mate you need a new regulator and battery" Its sheer guesswork on their part.
#16 |
Here is the verdict, my battery is charging fine, but there where a few more surprises in store.
Here a bit of the history of this unfortunate event. 1. Its winter and my battery seems to be on its way out. 2. I purchase a new battery 3. My bike stops at a traffic light with a totally flat battery, after a push start I get it going but have to keep revving it to 5000 rpm to keep it going, 4. The store exchanges the battery on two occasion. Apparently a bad batch of batteries. ![]() 5. New brand of battery and you guessed it... runs flat. 6. Get a second hand Yamaha regulator and install it. 7. The problem persists 8. Thanks to this forum I get my hands on the universal trouble shooting guide for charging systems and start investigating. 9. The ignition switch looks suspicious but turns out not to be the problem 10. It looks like the cable between battery and the regulator is faulty. 11. Replaced the cable with a direct bridge cable fused with a 30 amp fuse. 12. All looks good and I decide to swap the Yamaha regulator with my original. 13. It may well be (13) the dam thing is failing again only getting 12 volt to the battery. 14. Put the Yamaha regulator back in and everything works fine. The moral of the story... before you buy anything get a multi meter and start measuring. In my case it was a matter of 2 component failing the regulator and the cable. Maybe the regulator failed because of the cable or vise versa. I hope that this helps someone else out there to avoid the trouble I went though. I can't thank you guys enough I would never made it with out your help. THANK YOU ![]() |
flat battery | jimc | SV Talk, Tuning & Tweaking | 5 | 15-01-09 10:32 PM |
Is it my Battery or Reg/Rec or Alternator?..i just dont know | Spiderman | Bikes - Talk & Issues | 11 | 21-05-06 02:23 PM |
is it my battery? - or my alternator? | branny | SV Talk, Tuning & Tweaking | 18 | 02-05-06 07:43 PM |
battery or alternator? | muzikill | SV Talk, Tuning & Tweaking | 5 | 16-01-06 12:45 PM |
SV battery - how long before it runs out and won't start? | Daz | SV Talk, Tuning & Tweaking | 14 | 25-12-04 10:03 AM |
