Old 26-02-08, 08:10 PM   #11
timwilky
timwilky's Avatar
Default Re: Any IT geeks in here
Have you ever notice, the problem is always with the last piece of kit you test?
Not Grumpy, opinionated.
Old 26-02-08, 11:16 PM   #12
Tiger 55
Originally Posted by Cam_73 View Post
Any IT geeks in here?
Answer yes!
Originally Posted by gomez View Post
reply from 66.249.93.147 bytes=32 time=34ns TTL=240
Tracing route to www.l.google.com [216.239.59.147]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 10.34.220.81
Old 27-02-08, 08:08 AM   #13
Cam_73
Heheh, Tiger, as always, astute concise and insightful answers
Okay, haven't tried any of this stuff as yet.
I really can't be bothered with the prospect of a few hours switching between dos windows and reboots. However I know I have to.
Background:
MOST IMPORTANT: Hookie copy of XP - Guilty
Decided that's not right - Guilty
Bought a MS Genuine advantage key - Guilty
So there's the background.
What I did next.....
Got rid of all the stuff i didn't need on the logical drive (6 Gb)
No problems.
Deleted logical partition.
No problems.
Tried installing SP2 for XP from MS Update was working ok although insufficient room on drive.
So deleted what appeared to be a part of the SP2 update according to add/remove software.
Then after some advice on here, went after partition magic.
This is when I found I could no longer download and started to get the HTTP 403 (Forbidden) error.
Tried update again and started to get same problem although MS reports it as some xxxxx13191A error (can't quite remember, I'm at work now)
Anyhow, I'll give the various options a try and report back.
Thanks for all the advice so far guys.
I am still thinking about a new box though
Old 27-02-08, 01:06 PM   #14
stuartyboy
...there's always someone who can pee higher than someone else...
SOLUTION - get yourself a MAC
Lights blue touch paper
Old 27-02-08, 03:12 PM   #15
Tiger 55
Ah, but there is one thing that PC owners can do that Mac owners can't...
Old 28-02-08, 05:35 PM   #16
gomez
[quote=stuartyboy;1430823]...there's always someone who can pee higher than someone else...
Surely you mean "IP" higher if referring to geeks.
The non-geek answer is to dump the old PC and get new and not waste time with the old.
The same could be said for bikes which is something i've failed to do on too many occasions.
Old 28-02-08, 06:06 PM   #17
duibhceK
a geek, moi?
let's eval()
- regular slashdot reader: 1!
- use dvorak keyboard layout: 1!
- loads of superfluous hardware: 1!
- using weird OS-es like linux, BSD, HP-UX: 1!
- spending way too muc time according to girlfriends taste on tinkering with - - home-made multimediacenters and PVR's: 1!
hmmm...
I guess the answer must be 42.
Old 29-02-08, 03:45 PM   #18
-Ralph-
Take it this got fixed then?
Old 29-02-08, 05:15 PM   #19
Tiger 55
Originally Posted by duibhceK View Post
a geek, moi?
let's eval()
duibhceK mate, having the faintest clue what the dvorak keyboard layout might even be pins you down as a geek!
geeks- help me Quiff Wichard Idle Banter 24 30-01-09 11:27 AM
Oi geeks. yorkie_chris Idle Banter 64 23-11-08 10:06 PM
So then Geeks Viney Idle Banter 4 06-08-07 11:21 AM
Only for the geeks falc Idle Banter 13 08-02-07 06:21 AM
Something for the geeks.... Baph Idle Banter 81 16-11-06 04:46 PM
