Old 24-03-08, 07:46 PM   #11
Default Re: Easy way to fix speedo with GSXR front
I'll stick some to your discs
Old 24-03-08, 07:52 PM   #12
richwill68
Awww, fanks!
Old 24-03-08, 11:32 PM   #13
How do you fix them?
I bought drilled ones and bolted them into the front disc rivets.
Old 24-03-08, 11:54 PM   #14
I just stuck them to the disc with magnetism for now- that works up to 100, haven't tested it past that. But with my Veypor, I did the same with a dab of superglue and it was rock solid.
Old 25-03-08, 09:26 AM   #15
Blue_SV650S
Anyone got a broken one to play with?
Didn't you say you had one .. get the hacksaw out man!!
Old 25-03-08, 01:56 PM   #16
Nah, the sensor for mine works and it's been modded to work with the rear wheel relocate, so I'll probably take off all the modded bits and stick 'em on Ebay as a kit
Old 25-03-08, 03:18 PM   #17
Stu
Trinity
Stu's Avatar
Awh no pics!
When I get home I don't mind adding pics of mine. Because I didn't upgrade the magnets I was very limited as to where I could place them. (they're currently not very good with tape but loathe to change it as it works at the moment.
Even placement of the 4 magnets is really not necessary as I have 5 magnets on mine, one doesn't work (but I can achieve 150mph on my SV! ) but it still reads quite smooth.
As to the speedo error, compared with a GPS I found that moving the speedo to a 120/70 made it more accurate, now it's on a 160/60 it is almost perfect but if anything definetely reads a higher speed than lower, i.e. safe
got 2 speedo sensors - one complete with broken magnets (21Quests' if he wants it back before I give it away ) & mine with good magnets but cut cable.
Old 21-05-08, 06:19 PM   #18
2 of them fell off on tuesday, on a trackday So glue them on- official. Luckily they didn't ping out the back and banjo the guy behind me...
Old 21-05-08, 06:46 PM   #19
richwill68
OK, here goes!
Have successfully transplanted front speedo drive to rear wheel and works fine. Have no pics at present but will post some later (If I can! I'm OK in the workshop, not too hot on the PC thingy).
Method is pretty easy. Need a bit of milling on the rear caliper hanger (about a fiver at a decent local machine shop). a piece of aluminium plate about 2-3mm thick and just 3mm bigger than the outside diameter of the rear bearing, a good hacksaw/files/plasters and a bit of patience. Sound good?
Well, the fitted part looks to all intents and purposes as though Suzuki meant it to be
I'll post drawings with dimensions when I get a chance.
Regards
Rich
Old 22-05-08, 10:02 AM   #20
Stu
Trinity
Stu's Avatar
You had someone behind you
speedo problem w/ GSXR front end catchsomesv650 SV Talk, Tuning & Tweaking 4 19-02-09 08:46 PM
GSXR front end speedo work around Lozzo SV Talk, Tuning & Tweaking 32 13-05-08 05:32 PM
GSXR Stuff for an EASY curvy conversion Stevetmanchester Stuff Wanted 17 28-04-08 08:46 PM
GSXR front end speedo conversion sensor svrash Stuff Wanted 11 26-01-08 11:52 PM
For those with GSXR Front ends & USA Speedo andyb SV Talk, Tuning & Tweaking 4 25-09-07 10:57 PM
