Old 27-03-08, 11:43 AM   #11
Viney
Default Re: Brake bleeding kit?
Sooooooooo many ways of bleeding brakes, and everyone has thier technique. I like the tube being held above.
Old 27-03-08, 11:44 AM   #12
Yog-Sothoth
If you have deep pockets, check out the Mityvac bleeder (around 40 quid inc P&P) from M&P. It cuts out all the tedious lever squeezing and nut cracking (and swearing).
Old 27-03-08, 11:48 AM   #13
jambo
jambo's Avatar
The one way valve kits can be more trouble than they're worth, Some of them require a fair bit of pressure to operate the valve meaning the pipe keeps popping off the nipple.
A long bit of clear tube and a bottle are my chosen tools.
Edit: If the rear brake still works, just fill the resevouir up, There's a fair amount of fluid held in the pipe so even if the resevoir's empty there may be no air made it as far as the rear master cylinder
Old 27-03-08, 11:51 AM   #14
A lot of people run the rear brakes with no reservoir, just a bit of clear tube directly onto the M/C, you can easily see and top up the fluid then. Save's a little weight if you're into that sort of thing.
Old 27-03-08, 12:27 PM   #15
Dangerous Dave
This is a good setup, its called a HRC setup and is lighter but more importantly it is easier to see the fluid level and top up.
Old 27-03-08, 12:28 PM   #16
I've always thought that the curvy rear brake res is in a really daft place too, right pain to get the top on and off.
Old 27-03-08, 12:49 PM   #17
sv650k4
i have a sealey hand pump bleeder and it works great on my sv and all my other bikes ive used it on!
Old 27-03-08, 12:55 PM   #18
flymo
flymo's Avatar
Is that this one? http://www.justoffbase.co.uk/Brake-B...e-Sealey-VS020 I was thinking of getting one of these, not bad at just under ?30. Obviously need a compressor though.
Old 27-03-08, 12:57 PM   #19
sv650k4
no thats not like my one mine is a bit different and in its own we blue box think it was around the £50 mark.
Old 27-03-08, 12:58 PM   #20
sv650k4
the one i have dose for a load of differen things aswell and not just bleeding your bike brakes.
Brake bleeding - for the millionth time. sv_rory SV Talk, Tuning & Tweaking 7 19-02-09 07:11 PM
Brake bleeding-where am I going wrong? rowdy SV Talk, Tuning & Tweaking 20 02-02-09 10:36 PM
Rear Brake bleeding. What am I doing wrong? petevtwin650 SV Talk, Tuning & Tweaking 8 08-04-07 06:30 AM
Bleeding new brake lines andyb SV Talk, Tuning & Tweaking 1 25-01-07 06:10 PM
Brake Bleeding - Two Questions Colboy SV Talk, Tuning & Tweaking 16 24-01-07 10:04 PM
