#11 | |
#12 |
You always want to replace both Sprockets and chain all at the same time, a worn chain will wear new sprockets or warn sprokets will wear a new chain!
#13 |
+1. And this wear will be much faster than a new chain & sprockets wear together. It's a false economy not to replace all at the same time.
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue. RIP SV650 X curvy, crashed and written off December 2019. I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road. |
#14 | |
![]() ![]() Thanks guys cheers |
#15 |
Sprocket set usually implies a pair, front and rear. Ask the seller/supplier and see if you were supposed to get both sprockets.
#16 | |
The kit above contains an AP/Apx grade chain, which Tsubaki recommend for the SV. I have found that their SG/SGX premium chain lasts appreciably longer & is well worth the extra £. Ask Derbybiker. Cheers. |
#17 |
All this is good- intobikes do a kit for about £80-90 for Tsubaki chain and steel sprockets. I shall be purchasing at the end of the month, as I've got a tight spot and it's getting to changing time anyway...
#18 | |
Wonder though if there is much quality difference in the steel rear sprockets between afam, jt, renthal, ... ? |
#19 | |
#20 |
Right ordered a renthal front sprocket 1 tooth less on the front.... Renthal alluminium lightweight rear sprocket and a gold Iris chain also while taking the rear wheel off i shall replace the rubber bushes in the wheel with new ones.
I was going to get the tsukabi kit but thought id spend abit extra. |
sprocket and chain Q | ricky | SV Talk, Tuning & Tweaking | 21 | 01-10-09 01:52 AM |
chain + sprocket | SVTristan | SV Talk, Tuning & Tweaking | 2 | 08-05-09 03:01 PM |
520 sprocket with 525 chain? | charlie13 | SV Talk, Tuning & Tweaking | 10 | 31-10-07 08:38 AM |
Sprocket/Chain | Mr. Bob | SV Talk, Tuning & Tweaking | 2 | 03-05-07 08:43 PM |
Chain and Sprocket | Ernie B | SV Talk, Tuning & Tweaking | 6 | 04-05-06 12:35 PM |
