Old 23-04-08, 07:05 PM   #11
Alpinestarhero
Default Re: Hello from Norwich.
Y'ello!
I went on a boating holiday round the norfolk broads once, and I fell in the river at norwich in all my clothes, just before the whole family went off for a meal.
Anywho, welcome to the forums
Bear is very freindly
Matt
Old 24-04-08, 12:51 AM   #12
missyburd
'ello and welcome to the .org!
Old 24-04-08, 05:02 AM   #13
BigBaddad
Hi JJ and welcome....Skip and I are fairly "local" to you.
Old 24-04-08, 06:52 AM   #14
Tiger 55
Ahoy!
Very flat, Norfolk...
Old 25-04-08, 04:07 PM   #15
SVrach
Hi JJ
Welcome,i've not been here long,only had my SV a few weeks. I'm not too far from you,nr Downham Market. Best of luck with your test
Old 25-04-08, 07:47 PM   #16
Skip
Skip's Avatar
Welcome! Best of luck with your test
'81 Honda H100A
'18 Honda MSX125 (Grom)
Old 25-04-08, 10:01 PM   #17
jimmy-james
Thanks for all the support, I will let you know how it goes!
Old 09-05-08, 08:11 AM   #18
jimmy-james
Well i passed and have run up several hundred miles on the SV and loving it!!!!!!
A couple of minor queries about the bike though. I seem to be having troubles with the clutch periodically dragging causing the bike to slowly move forward even though the clutch is in, the second problem is third gear is sometimes hard to select. The bike has been stood since late 2007 so i suspect some good hard use would not go amiss!
Old 09-05-08, 08:43 AM   #19
Give it an oil change and check the chain adjustment, that's always a good start.
Old 09-05-08, 09:08 AM   #20
jimmy-james
I have done both mate and it is a bit better, the funny thing is it is not all the time. The chain and sprockets need replacing because it has a really bad tight spot on it, i am trying to work it out by adjusting the chain to the tight spot daily and lubricating it with heavy gear oil as recommended by the local dealer. Its not getting any better so i think it will have to be done soon!
servicing in norwich/norfolk fadedhalo East Anglian Revolution 8 30-06-09 10:13 PM
1996 GSF600 Bandit For Sale Norwich jimmy-james Idle Banter 4 29-04-08 05:18 PM
sv spotted- norwich james160987 Bikes - Talk & Issues 0 29-04-07 08:45 AM
Norwich Union Hospital Cash Cover Insurance Ed Idle Banter 1 27-04-06 08:28 AM
