Old 29-04-08, 12:18 PM   #11
MiniMac
Default Re: This doesn't look good (brakes)
OK, I've taped it up with gaffer tape.
Are these just push fit over a small ridge? SV Spares for one of these jobbies? Getting a new gear lever, wing mirror and clutch lever today, so will try and lump that in too.
MiniMac is offline   Reply With Quote
Old 29-04-08, 03:28 PM   #12
Push fit? No I think they're swaged on and not seperable from the banjo fitting.
You'll have to undo the banjo-bolts at each end to replace it, it is also reccomended to replace the washers when you do this. (cheap enough)
Tip of the day... hang something heavy on the brake lever, that way while you're putting the other hose on, the fluid in the reservoir doesn't all leak out.
Old 29-04-08, 08:29 PM   #13
I'm_a_Newbie
Osram H4 Nightbreakers on Ebay for ?20 a pair including delivery. Very good bulbs.
Tim.
Old 29-04-08, 08:34 PM   #14
Lozzo
Send me a home address and I'll pop a standard brake line in the post for you. I have a couple of good ones here spare after fitting braided lines. They'll only end up in the bin.
Old 29-04-08, 08:52 PM   #15
andyharding
Change it. Not worth risking your life over.
Old 29-04-08, 10:10 PM   #16
It's the rear brake so hardly likely to result in instant splattery, biggest danger is total loss of fluid onto the tyre.
Anyway still change it.
It's good to know there are still good people in this world andyb Idle Banter 14 17-06-08 05:16 PM
No Brakes The Mass SV Talk, Tuning & Tweaking 13 16-11-05 11:01 AM
is there a good mechanic,by good i mean cheap wigan650s The Madlanders 3 01-09-05 08:53 PM
Brakes TSM Bikes - Talk & Issues 13 11-02-05 09:47 AM
Good bike, sit, stay......roll over , theres a good girl! 454697819 SV Talk, Tuning & Tweaking 13 16-08-04 09:35 PM
