Old 30-04-08, 09:43 AM   #11
Default Re: Question about oil level
2700 following engine overhaul, dry engine,new filter.
That's about right anyway, apart from what was sloshing about in there from assembly of the other SV I've got...
I think you're right about the oil cooler needing more volume to fill.
Old 30-04-08, 09:48 AM   #12
TightRS
TightRS's Avatar
Interesting.
Haynes state for a Curvy mind you.
2300ml for oil change
2400mls oil and filter
My 99 - 05 Haynes says the same as above ^. (Doesn't mention if for curvy/pointy at all though).
My K5 manual only shows 2300ml oil, 2700ml for oil & filter. (Doesn't mention overhaul)
The '03 PDF Service Manual (off the .org) says the same as my K5 manual ^, but also mentions an 'overhaul' as 3100ml.
I've just had a look in the shed and i've got 1300ml left of Shell VSX 10w 40. Although I used the same guage on the container to fill the bike with 2.7L bit by bit, then checked it was then full at the sight glass.
I wonder if the oil cooler on a pointy doesn't drain without the filter being removed?
I remember having to tilt the bike over repeatedly for ages after removing the filter to get all the oil.
SV650S K5
GSX-R Shock, R6 Throttle, Oxford Hot Grips, R&G Crash Guards, Hugger, Fender Extender, Radiator Cover, Mirror Extenders, Stebel Magnum Horn, DL Handguards, Philips X-treme +80%, Denso Iridium Plugs.
TightRS is offline   Reply With Quote
oil level question davepreston SV Talk, Tuning & Tweaking 10 21-03-09 11:30 PM
hi level link pipe question t18con. SV Talk, Tuning & Tweaking 9 26-08-08 09:12 PM
anyone wanna swap my hi level leo vine for a low level one spakmitten Exhausts 1 16-06-06 08:59 AM
anyone wanna swap my HI level leo vince for a low level one spakmitten SV Talk, Tuning & Tweaking 1 16-06-06 05:25 AM
heat shield for high level question lodman27 SV Talk, Tuning & Tweaking 3 01-09-05 01:28 AM
