Old 09-05-08, 10:37 AM   #11
John Burt
Default Re: Calling all mecanically minded
Got an alarm/imobiliser fitted; not unknown for them to give misfire at high revs
Old 09-05-08, 11:06 AM   #12
neio79
I bet you a shiny penny it is a spark plug breaking down/problem
Had exactly the same symptom on my SV ... it was a dodgy plug ... sometimes it'd rev fine, other times it just felt like it wasn't pulling as hard as it should ... but not as if it was totally down onto just one ...
If you think about it if one (or more) cylinder is under performing, not only is that not giving much power out, but the others are then fighting it staking the power away from them ...
As you have identified, it could be something more s3xy like the power valve or valves themselves, but I'd go for the plugs first
Not thought about the spark plugs. I do tend to use a jet wash and stick it behind the faring to claen the engine block. I wonder if some water had ingressed into one of the plugs or i have lossened a cap on them with it??
but wouldent it have dreid out by now??
Lambda sensors have the potential to muck up the fuelling, as do the spark plugs as blue says, as does a sticky EXUP valve. (wouldn't expect carbon deposits on such a new machine though)
Basically it's a complicated EFI system, if it's showing no fault code then there's no real way to know whats fubarred, also your dyno run could show up perfectly healthy as you've got an intermittent problem
Have a check over for loose connectors and stuff, that's a distinct possibility too.
yeah this is what is frustrating is got sensors everywhere there is no fault code at all, i suppose the dyno will show up a lamba sensor error in the fuel/air mix read out. As if its running far to lean the power will be down a fair bit??
only a factory standard Kawasaki igniton imobiliser.
Old 09-05-08, 11:08 AM   #13
Aaaarrrghhh jet washing! Don't do it!
Have you tried taking the HT caps off and letting them dry out? Same with all the electrical system connectors.
Old 09-05-08, 11:17 AM   #14
neio79
yeah i know, but it makes it very shiney!!
not yet i will tonight as well, might explain why it splutters and stalls on first start up after a wash, and i do wash it a lot.
Old 09-05-08, 11:32 AM   #15
Blue_SV650S
Mine was an actually faulty plug ... i.e. the plug itself must have started breaking down (nothing to do with water in the plug cap etc).
Do you have some old 'known' plugs you could pop in??
As I said, the symptoms are identical ... so it has to be worth a try before getting heavy/expensive ... a new set of plugs would do it no harm anyway will it
Or you might have indeed just loosened a cap
Old 09-05-08, 01:05 PM   #16
neio79
Default Re: Calling all mechanically minded
i dont have any good plugs but after checking all other easy posibles i will change them just to rule them out.
Old 09-05-08, 01:15 PM   #17
neio79
was it easy to see that the plug was knackered?
Old 09-05-08, 01:20 PM   #18
Blue_SV650S
No visible signs no. It wasn't completely shot remember, just intermittently breaking down (I assume internally). The bike would start, idle and run fine, just sometimes, it lacked 'spunk'!! ... changed the plug (had to be worth a try) and hey-presto
Old 09-05-08, 02:14 PM   #19
neio79
well after checking basics like connectors are dry inside and all tubes ect are unblocked and where they should be, new plugs will be my next port of call.
Although it did have this problem before and after the first 600 mile service where they are changed arent they??
Old 09-05-08, 02:17 PM   #20
SoulKiss
SoulKiss's Avatar
nope not changed until 8k I believe and then ecery 8k thereafter - doesnt have an interval based on time.
Thats for my Z750 anyways - woiuld have thought you would be about the same
Help the mechanically inept! JediGoat SV Talk, Tuning & Tweaking 5 12-05-08 10:36 AM
One for the PC-minded, hard drive problem northwind Idle Banter 7 11-09-07 06:50 PM
For those more technically minded than me... andyaikido Bikes - Talk & Issues 10 07-04-07 11:39 AM
fitting a new exhaust - for the mechanically inept drumroll SV Talk, Tuning & Tweaking 12 18-05-06 02:50 PM
Three simple 2002 SV650 questions for mechanically minded... paulsemale SV Talk, Tuning & Tweaking 11 17-08-05 09:02 AM
