Old 12-05-08, 01:19 AM   #11
jimmy-james
Default Re: Is my clutch failing?
Mines the same but it only does it occasionally. I changed the oil and it was a bit better and have cleaned the worm gear, tensioned and lubed the chain but its still doing it although its much better than it was. Next thing will be the adjustments hope that will solve it
My bike has been standing since 2007 and my local dealer said worst case senario is dismantling cleaning and re-oiling the clutch plates or replacing them as the plates can stick together with lack of use causing it to drag, apparently!
Old 12-05-08, 07:17 AM   #12
jumjum_0214
Check your oil level.
Old 14-05-08, 07:01 PM   #13
ukrobuk
I'v checked the oil leval, evan changed it for the same oil i used befor the problem, oiled the chain and cleaned everything else and adjusted everything. Still no hope, might have to sell my Wii to fund a garage to fix it for me. Anyone want a Wii? The console sort that is. Right i'm off to sulk a bit in the garage, in the nice sun
Old 14-05-08, 08:15 PM   #14
aadeyc73
I'd see if someone could cast there eyes over it before going to a garage, where abouts in Oxfordshire are you there might be someone nearby that can help you.
Old 14-05-08, 08:40 PM   #15
muddycoffee
Yes but have you actually changed the cable for a new one ?
Old 15-05-08, 11:44 AM   #16
chakraist
If you take off the little clutch cover on the left hand side of the bike, give that all a good clean out as there tends to be a lot of crap that gathers in there. Next thing, pull the clutch lever in and check it to see if it's moving at the correct rate down the left hand side. Failing that take the worm gear out and adjust that, it's quite easy to take it the other way so that the clutch is permanently engaged. Sorry if you already know all this.
Ooh also you should check the push rod as mine sheared in half once.
Old 15-05-08, 10:27 PM   #17
Your description has 'clutch drag' written all over it - there's almost certainly nothing wrong that won't be solved by being adjusted right.
If your clutch were failing it wouldn't grip enough - yours is gripping too well.
Old 17-05-08, 10:48 AM   #18
ukrobuk
Hi i'm in Witney West of Oxford, The only thing i havn't tryed is changing the cable, i'll try it today, but thats the last of the things to try, got myself a haynes book, says somthing about the plates could have stuck together or somthing?
Thanks for all the help i'll be giving my clutch another go today. 3rd time lucky
Also my net seems to be nackered 2 so having problems getting onto the site at the mo.
Old 17-05-08, 11:51 AM   #19
chakraist
If you remove the clutch mechanism, worm gear etc and then the push rod, you can spray some wd40 or similar in the little 'ole that the push rod fits in, adjust it all properly and it should be fine.
Old 17-05-08, 07:04 PM   #20
ukrobuk
Ok i made some progress today, i took some engine oil out so its now halfway between Max and Min instead of being on the max line. Anyway left the plastic cover off while i went for a 10min spin. I can now get in N with ease but if i'm in 1st and stopped the bike still wants to move, at this point i looked at the side and noticed somthing i hadn't befor.
The small rod was spinning sort of, it was trying to spin but getting stuck sometimes. Ok i don't know allot about this but i guess the rod is ment to spin freely, but when? Is it ment to spin 100% of the time or what? Anyway i'v marked the rod on the pic and could this be my problem? I'v currently taken bits off the bike and following what chakraist says i should do (post above this 1). Never noticed it spinning befor i think it must have been well and truly stuck befor.
Also i got a new clutch cable in the post.
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
hey new clutch advice Kyoto Clutch srxaus SV Talk, Tuning & Tweaking 3 14-08-07 04:25 PM
My memory is failing. timwilky Idle Banter 3 02-12-06 06:56 PM
clutch on the way out? wtdafk Bikes - Talk & Issues 2 16-06-06 02:35 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
