#11 | |||||
Trinity
#12 |
Head off is really easy on the front one, no you don't need to remove the engine.
Radiator off, intake unbolted, cam chain tensioner removed, cam cover off, cams out (taking care not to drop cam chain into engine) head bolts out (will need a long 12mm 1/2" drive socket) and head off. I invested in a Haynes manual for all the direction re setting up the cams and torque settings for the rebuild. Helps if you line up the timing marks before removing the cams and don't turn the engine whilst apart. Good luck. |
#13 |
I had just about the same problem with mine (finished job last night), I just had the one bolt shear off, I tried everything to get it out but had no luck, in the end I drilled it out to 5.1mm and tapped it 6mm then made up a stud thats 6mm on one side and 8mm the other, loctited that in and also put an 8mm stud in other side, the 6mm part of the job is plenty strong enough to nip up the front pipe to get a seal, all is well until I take head off for big bore kit
#14 |
A secondhand head will probably be cheaper than spark erosion if bodgetastic ways of removal don't work.
I'd always drill and tap rather than use a stud extractor on account of them being horrible.
#15 |
Trinity
#16 |
![]() ![]() Thats where your problem is, someone has replaced the studs with cheap ally bolts!!! Should look like below.... Last edited by Dangerous Dave; 29-07-08 at 04:36 PM. |
#17 |
The headers on my pointy had cheap old ally bolts looks a better set up you got though DD, nice shiney pipe there!!!
RIP Hovis - Unlucky Boyo
#18 |
Trinity
#19 |
Sorry for the semi hijack. As this seems to be a common prob with these bolts.... Would it be prudent to change them early on for better bolts and use copper grease to make sure that when you actually need to take the pipes off you can?
Just thinking of poss saving myself some grief in the future! ![]() |
#20 | |
Knob faced knobster
Anyone with a pointy that confirm whether they're the same bolts?
2011 Speed Triple 1050 |
Race headers | weecorey | Stuff Wanted | 1 | 18-04-09 12:30 PM |
hindle headers | carsounds_dan | SV Talk, Tuning & Tweaking | 4 | 29-08-08 12:25 PM |
leaky exhaust headers | sixstring | SV Talk, Tuning & Tweaking | 5 | 11-06-08 12:27 PM |
Are curvy headers different to pointy? | stuballs | SV Talk, Tuning & Tweaking | 6 | 18-05-08 10:52 AM |
Time to remove pointy lower fairings? | Reckless Rat | SV Talk, Tuning & Tweaking | 9 | 03-07-06 07:22 AM |
