Old 27-05-08, 08:05 PM   #11
Camel
Default Re: Any builders on here?
OK, well I guess I should say it is more of a conservatory than an extension....just a great big old room on the back of the house! I have attached a picture for all too see, I'm sure some of you are just curious (i.e. nosey!!).
If you look at the wall by the fence, you will see that there is no point having a window there. Also the ground slopes, so the fence doesn't go all the way to the bottom of my wall, but actually sits on a brick wall.
Anyway, the builder is a very good guy - I don't think in any way he is trying to con me. The price he quoted is very reasonable.
I am just concerned that it is a safe / ok thing to do, building wise. All I would ask is that depending how high the wall goes, that a regular house brick is used as you get near the top of the fence (assuming it is safe / acceptable to use block in that way).
Old 27-05-08, 08:09 PM   #12
GSXR Carlos
block will be fine for the purpose you've described.
the only reason brick is used is because it's prettier
we build whole double skin walls (like yours) out of block and then render the outside. as long as the ties are installed, and movement joints etc then safety is not an issue
but, as always, speak to a professional - cos i don't have professional indemnity insurance - lol
Old 27-05-08, 08:12 PM   #13
magicrat
structurally it makes no difference really if its brickwork or blockwork - so the job looks fine regarding this. The only issue is the aesthetics of the wall. As you point out, if the fence comes down it'll look a bit of a mess - but then that could be covered with render, so it won't be the end of the world.
Old 27-05-08, 08:14 PM   #14
Ed
How are you going to maintain the fence?
Old 27-05-08, 08:34 PM   #15
GSXR Carlos
does the rule about the left side fence still stand?
Old 27-05-08, 08:44 PM   #16
Ruffy
Ruffy's Avatar
+1. This is also my understanding. The conservatory we have is very similar in that we have a block wall on the outside face next to the fence.
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue.
RIP SV650 X curvy, crashed and written off December 2019.
I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road.
Ruffy is offline   Reply With Quote
Old 27-05-08, 08:50 PM   #17
Ed
Nope. There never was one.
Old 27-05-08, 08:59 PM   #18
GSXR Carlos
i thought someone was always responsible for one side of their garden?
Old 27-05-08, 09:18 PM   #19
Ed
Often but not necessarily. It depends what it says in the title. Sometimes the title is silent, so often it largely depends on custom and use. Most land in England and Wales is registered, you'd have thought that the Land Registration Rules would help, but they don't - in fact they state (rule 278 to be precise) that the red line on the boundary plan is not indicative of ownership of boundaries. Completely useless. So it's not surprising that so many people fall out over fences, often it's simply impossoble to advise people on the matter. Incidentally I do this for a living - I'm a solicitor.
Old 28-05-08, 10:31 AM   #20
Camel
I'm planning on letting it fall down
Seriously, I've not done any fence maintenance in the past few years. if it need replacing, it'll have to be done from the other side. The neighbours are ok.
On the legal side, I have no idea who is responsible for the fence.
Good stuff! I am not alone!
Thanks for all the reply's guys.
Any kitcar builders on here? Paul the 6th Idle Banter 31 03-12-08 01:29 PM
The three little cowboy builders gettin2dizzy Idle Banter 7 28-01-08 01:11 PM
Any builders on the site ? stewie Idle Banter 14 19-10-07 01:46 PM
One for the builders/tilers Tris Idle Banter 5 10-05-07 09:06 PM
any builders?? my breezeblocks are leaking hovis Idle Banter 40 30-12-06 10:37 PM
