#11 |
the problem is that quite often when you are working on the bike the rear seat needs to be off which triggers the tamper switch (as stated above) alarm unless its in service mode, then your back to that annoying beep .
#12 |
Mine is the silent version of this. (By that I mean that it doesnt beep when you arm/disarm it.)
To get it into ferry mode: Arm the bike: 2 Indicator Flashes Press the other button within 15 Seconds: 3 Flashes You can move the bike as you wish. Just dont turn the ignition on without disarming it - it set the alarm off. |
#13 |
At the risk of being semi ignorant (though I have read the instructions and got more confused than I was when I started...) how do you stop it self setting itself when the ignition is off, but you've not armed it fully - i.e the beeping that gets faster?
Very odd looks at petrol stations, etc ![]() Failing that, how do you stop the beeping?! |
#14 |
Arm it then disarm it?! (Press button twice)
#15 |
![]() ![]() For mine its one press of the round button to arm the system (2 bleeps) then one press of the oval (1 bleep, lower tone) to disarm the movement detector. When ready to go one press of the round to disarm the rest. |
#16 |
With mine the motion/movement sensor does not activate under self arming conditions . If I leave the bike to self arm I can then still move the bike without any problems .If I arm the bike then it will beep at every encounter . However I frequently was and service the bike with the alarm active but under self armed status . With this it gives me the freedom to open up and move the bike without the annoying beep .
Oh by the way I removed the tamper/seat switch the day I got it fitted . |
#17 |
with the seat switch it should only trigger the alarm if the status cahnges ie you open or close the switch. so if you take the seat off then do your ferry bit you maybe able to leave the seat off and the alarm will only go off once you put the seat back on. (thts only if you dont diss arm it first) its only a pssibility as mine does it but its a lazer line.
hth scott |
#18 |
yes that would work with datatool 3 scott and seems to be the best possible way round the annoying beeps from the service /valet mode.
Datatool System 4 Red | TSM | Bikes - Talk & Issues | 47 | 23-09-21 06:20 AM |
Datatool system 3 PIN? | nobby | SV Talk, Tuning & Tweaking | 15 | 23-03-09 10:17 PM |
DataTool System 3 Problems | squirrel_hunter | SV Talk, Tuning & Tweaking | 9 | 25-04-08 08:39 PM |
Datatool system 3 | suzsv650 | Bikes - Talk & Issues | 1 | 04-07-07 01:26 PM |
Datatool System 3 | TSM | SV Talk, Tuning & Tweaking | 1 | 16-07-05 11:48 AM |
