Old 20-06-08, 10:56 AM   #11
TeddyBearKing
Default Re: 650SK3 engine unit needed
Originally Posted by Sideshow#36 View Post
I have 90% of a K3 engine. All it needs is a front cylinder head, cams and rocker cover. £220??? However I would recomend you collect it as I had to pay over £50 to get it posted.
Thanks for the offer mate, i still have a few people i need to talk to, but if dont get any luck i will come back.
Just a question, why are you selling the engine? and how many miles has it done?
Old 20-06-08, 10:59 AM   #12
plowsie
Originally Posted by TeddyBearKing View Post
One garage said that excessive wheelie-ing would drain the front cylinder of oil and cause heavier wear
That mate, is very true, heard quite a few cases of it. But I would've thought the wear would be around the insides not the outer shell.
but still...i just cant wrap my head arround what happened and how
Me neither.
Old 20-06-08, 11:01 AM   #13
21QUEST
21QUEST's Avatar
Originally Posted by touch107fm View Post
Sorry to hear about your unfortunate incident :9 . As it goes, I have an engine with similar damage hear.....bought it like that mind.
That's a good price.
Ben
Nemo me impune lacessit.
Old 20-06-08, 11:05 AM   #14
plowsie
I retract my earlier statement about the insides after a bit of research, overheating can cause cracks in the casing, so if the front cylinder is being starved of course the engine will be overheating, causing your cracks, but maybe it started on the inside, hence you didn't pick it up...
Originally Posted by Some Website
The most common cause of cylinder head cracking is overheating. When a vehicle overheats, it puts stress on all of its metal components, including the cylinder head, which is often at the center of the heat. This can cause the head gasket to fail, which may lead to cylinder head cracking as the components warp and pressure begins to leak. All drivers should properly maintain their vehicles to prevent overheating.
Please ignore me if I am talking boll0x lol. Not much help to the OP so will shut up now
Old 20-06-08, 11:19 AM   #15
Sideshow#36
This was my spare engine at the start of the season. I now have a slightly newer K4 engine as my spare so I no longer need it. I had a miss hap drilling out the Ehaust bolts on the front cylinder head on my race engine so I needed to nick that cylinder head. Hence why it is missing. It had just over 9K if I remember rigthly.
Old 20-06-08, 12:05 PM   #16
ivantate
Must be the conrod snapped to push that out.
Supposedly it does happen occasionally on SVs, but usually at 40000+ miles. Always on the front cylinder.
Old 20-06-08, 04:15 PM   #17
Thrown rod, K3's are the worst of the bunch for it or so I've heard.
Strip it down and find out.
Old 23-06-08, 05:41 PM   #18
TeddyBearKing
Well, George White have taken it in now, so I will have to see what they say.
Please forgive me, but i dont have much knowledge of engines, just the basics...what do you mean by 'Thrown rod' ??
Old 23-06-08, 05:46 PM   #19
The connecting rod snapping at the small (piston) end, which then gets "thrown" outward by the spinning of the crank at high speed and hits things.
I'd be interested in the knackered engine just out of curiosity.
HELP tool needed for engine work Pokerboy89 Bikes - Talk & Issues 4 23-04-09 05:55 PM
650SK3 engine unit needed TeddyBearKing Bikes - Talk & Issues 0 19-06-08 09:41 PM
Engine paint - help needed 5hort5 Bikes - Talk & Issues 8 17-02-08 03:55 PM
Engine timing, advice needed please ? Soprano69 SV Talk, Tuning & Tweaking 17 21-01-08 09:54 PM
Engine gasket needed spamrot Stuff Wanted 0 19-12-06 02:16 PM
