Old 25-06-08, 04:50 PM   #11
DMC
Default Re: Drew Carey off!!!
Hope your ok Drew
Old 25-06-08, 04:53 PM   #12
tanis34
hope all is well but it sounds like hes out of the frying pan and into th fire
Old 25-06-08, 04:54 PM   #13
SoulKiss
SoulKiss's Avatar
Have to say the worst part of my off when I wrote off the SV was phoning home......
Old 25-06-08, 04:57 PM   #14
tanis34
yes its not the nicest of calls to have to make
Old 25-06-08, 05:14 PM   #15
Tara
hope your OK Drew
Lily are you OK hun?
Old 25-06-08, 05:33 PM   #16
Girth
Hope your ok Drew dude, but come on more info!!!
Old 25-06-08, 05:52 PM   #17
Sean_C
Hope you're okay matey.
Old 25-06-08, 07:16 PM   #18
Drew Carey
Not Fizzwheel
Drew Carey's Avatar
Right, info for you all......
As far as crashes go I feel embarrased to say it is the most useless one known to man.
Behind a lorry, all of a sudden he slams his brakes on and skids the lorry as another was coming the other way and they were about to scrape.
I didn't have time to stop, slammed on anchors skidded into the back of lorry at 5mph, bounced back off lorry and the bike dropped on the floor. I jumped off as the bike went so I am fine.....
The bike has a scrape on the R&G's and a scuff on clutch, gear selector, side stand and rear axel nut on left side. The point where I hit the lorry is the worst.......It has cracked my front fender and the brackets that hold the lights into the front fairing broke.
I got to my folks and me and my old man have taken all the front off. Used araldite and fixed the bracket etc so the light is again holding firm. Also had the front fender off and araldited the crack and used car body filler to cover the evidence. Now ordering some paint and will be spraying it next week when off work before the AR. So once that is done all that will look damaged is the R&G.....but heh ho.
Lily has hit me many times and deservedly so...I also feel so annoyed with my self that I wasn't further back. But lesson learned....So...........
By all means now take the mick out of me and call me a donkey cause I was.
"Feckinnnn Unluckkeeeeeeee"
Old 25-06-08, 07:20 PM   #19
Lissa
Just Ballast
Lissa's Avatar
Drew.................you're an ass!
And thoroughly deserve the belting you got from Lily
But you're ok, the bike is only cosmetic............and I'm damned sure nearly everyone gets a little too close to the vehicle in front occasionally. Just don't do it again
Old 25-06-08, 07:21 PM   #20
Girth
Hey no need to feel like a donkey, at least you are still here/ok to type about it. Plus it could of been alot worse if it was wet, it happens to us all.
So did the R+G's do their job then?
Yay for Drew...... lily Idle Banter 19 17-11-08 02:18 PM
Watch out Maria Carey Lozzo Idle Banter 10 27-10-08 12:53 AM
Mariah Carey plowsie Idle Banter 18 03-04-08 04:24 PM
