#11 |
Absolute must - get her to lean with you! If she dont you be going straight on!
nb650 |
#12 |
#13 |
Toolkit is (on K5 at least) just in front of the rear tyre, accessed through a little box at the left of the bike. C-spanner is a hooked semi-circular thingy - the toolkit one is ok but a ratchet attachment one is dead handy. At the base of your rear shock will be a ring of teeth on a gradual incline, turning that ring with the C-spanner results in more or less preload on the shock. Pre-load doesn't equate to stiffer or softer, it's purely to set the sag (ie. the amount of travel the suspension uses when loaded just by itself, yourself, and pillion) - without adjusting this I'd suspect you run quite a risk of bottoming out the suspension over some bumps.
Oh and the front end will dive under braking a lot more than you're used to, stopping distances will be considerably longer. EDIT: Oh, and I didn't know where the toolkit was either till 2mths pointed it out to me at Foxes ![]() Last edited by MiniMatt; 08-07-08 at 04:34 PM. |
#14 |
I do 2-up but dont make any changes. I just do the usual of checkin tyre pressure, chain lights etc. Does that make me a bad person
Red Riding Ch4 | dizzyblonde | Idle Banter | 9 | 05-03-09 11:04 PM |
Riding with no end can | Blue_SV650S | Bikes - Talk & Issues | 19 | 29-09-08 11:20 AM |
Riding with others | Tina | Bikes - Talk & Issues | 16 | 19-07-06 11:05 PM |
Riding a SV again... | Grinch | Bikes - Talk & Issues | 8 | 02-03-06 12:46 PM |
Oi, what you riding then? | BURNER | Bikes - Talk & Issues | 46 | 18-07-05 10:12 PM |
