Old 16-08-08, 11:09 AM   #11
Dangerous Dave
Default Re: rim change...shop or do it myself?
Most would have them in stock, its not the matter of them fitting the wheel it is the matter of the spindle/axle fitting through the bearing.
Go to your nearest Suzuki dealer, they would have a stronger chance of having them in stock, if not try online.
Old 16-08-08, 12:27 PM   #12
skumlerud
Originally Posted by F16Falcon View Post
Rim=Thing that the tire is mounted to. Thing made out of aluminum and that get's bent from rough roads. Thing that tire slides around on if not properly inflated. If you completely took apart your wheel, the metal thing you'd be left with that has spokes is the rim.
So what would you call this then?
The thing that you call "rim" above is a wheel. A wheel consists of the rim, the spokes and the hub.
Old 16-08-08, 12:28 PM   #13
Dangerous Dave
Now that is a rim!
Old 17-08-08, 02:48 PM   #14
F16Falcon
Some kind of magical rings. Perhaps from some kind of time machine? I'm not an engineer, but thats my guess.
Old 17-08-08, 03:06 PM   #15
Lozzo
As K seems to be in hiding.....
You said RIM !!!
TEEHEE
That girl is utter filth...I like her.
Old 17-08-08, 03:13 PM   #16
Lozzo
Originally Posted by Dangerous Dave View Post
Try an English dictionary.
Judging by the spelling of the word 'tire' I would hazard a guess at the original poster being one of our colonial cousins from the USA, where the term 'rim' is not just an activity practised by the homosexual community, but also refers to what we would call a 'wheel'. This is a slang term, in much the same way that we in God's own country refer to a 'motorcycle safety helmet' as a 'skid lid'.
Old 24-09-08, 03:34 AM   #17
F16Falcon
This is great but does not mention bearings. I will have to install new bearing in the new wheel. Is that tricky at all. grease em and stick em on.
Originally Posted by jambo View Post
a) Remove calipers
b) Support front of bike off the floor
c) Remove front wheel axle and wheel (being careful of speedo drive)
d) Remove discs from current wheel (be careful not to put weight on them as they bend easily) Note which is left & right otherwise your pads will have to bed in again to some extent
e) Take old and new wheel to tyre shop, get them to move the tyre across.
f) Put discs on new wheel (noting which was left and right and replacing the same side)
g) re-install wheel
h) re-install calipers
Old 24-09-08, 09:07 AM   #18
jambo
jambo's Avatar
You will need the spacer out of the old wheel. This goes between the 2 bearings. The new bearings will need to be tapped into the wheel using a hammer and a suitable surface so you are not hitting the new bearing itself with a hammer, many people use the old bearing as a surface to hit.
When tapping in bearings make sure they go in square as they're tougher than the wheel!
I've not done this on an SV650 front wheel, but some wheels have lips on both sides to stop the bearings being hit in too far, and some have only on one side. If this is the case tap in the one with a lip first, then install the spacer from the other side. Now tap the 2nd bearing in, and if there's no lip, you'll need to tap it in square, a little at a time from each edge, until the inner bearing surface is *just* touching the spacer, but is not stuck onto it with any force. With your finger you should be able to turn the bearing independently of the spacer, but they should be pressed together so the surfaces meet. If you go too far the bearing will be stressed and wear out faster, too little and the hub won't be quite the right width.
If in doubt, it may be worth getting a workshop to do this as it won't take them long.
Hope some of the above helps.
Jambo
Old 24-09-08, 09:19 AM   #19
SoulKiss
SoulKiss's Avatar
Ahh but have you met her ????
Old 24-09-08, 10:41 AM   #20
Stu
Trinity
Stu's Avatar
Oh, I'm sorry it's the FRONT rim. I bet that helps.
At least we know there's a speed sensor involved now
And if you had graced us with whether you had a curvy or a pointy, if indeed it is an SV650, we could tell you the difference about the spacers.
Anyone shop in GAP? Viney Idle Banter 0 14-11-08 10:12 AM
Change in weather= Change in diet Dicky Ticker Idle Banter 5 15-08-06 06:51 PM
Where do you shop... Jdubya Idle Banter 13 27-06-06 10:30 PM
big shop Warren The Essex Lounge 10 31-12-04 05:06 PM
