Old 19-08-08, 07:47 PM   #11
Sideshow#36
Default Re: Suspension flow chart
Pretty good that, luckily I have a bit of help on race weekends off a pretty experienced racer. However most of the problems on there i've solved the same way, luckily I havnt enountered a few of them. The worst one was the rear spinning on exit, sure enough reducing the preload and winding off the compresion worked a treat.
Top stuff Luke.
Old 19-08-08, 08:50 PM   #12
phil24_7
I pay someone to set it up for me!!
Old 19-08-08, 10:43 PM   #13
lukemillar
A bit concerned they think preload and damping solves everything i.e. if the front has excessive dive, its probably coz you are undersprung ... slapping on more and more preload and or damping might cause other problems!!
But as I implied in my edit, if you overlook this part, it is deffo pretty nifty!!
So that was for the front end ... do they have one for the rear end too?
There is shock stuff there - just mixed in. I think the preload stuff isn't laid out in the best way. I read it as check you sag and adjust from there. I think the idea is "How to get the most of the suspenders you already have", rather than do you have X problem? ->Yes, buy an Ohlins!
Obviously, there will be limitations in your bikes adjustability and in the chart above, but from my understanding, I thought it seemed like quite a good starting point if you want to learn about all things bouncy
Old 19-08-08, 11:09 PM   #14
ThEGr33k
Yep told me what I know. Need a better rear shock to raise rear ride height and to stop the damn back end bouncing when im on the power hard out of corners...
Cheers though always nice to be shown what you know is right.
Old 20-08-08, 11:54 AM   #15
Blue_SV650S
No I mean rear end problems ... that chart is focused around the front end (sure some front end problems are caused by rear end, but all symptoms here are front end).
Old 20-08-08, 12:55 PM   #16
ThEGr33k
Read getting out of the corner... Thats mostly rear. I.E. the wollowing out of corners when pushed like what I get.
Old 20-08-08, 02:01 PM   #17
jambo
jambo's Avatar
I would imagine that has more to do with damping or throttle control than ride height
Unsurprisingly perhaps most of the shock settings are based on "Exiting corner" as this is when you are loading the bike's weight onto the rear tyre and highlighting any issues with the shock. Not that a bad shock setting can't cause issues elsewhere, but this is where it's going to be most apparent.
Jambo
Old 20-08-08, 04:45 PM   #18
Blue_SV650S
On a re-look, yeah, 'spose its pretty much covered too isn't it!!
Old 20-08-08, 06:09 PM   #19
ThEGr33k
You are right about the dampening. The shocker I have is crap for that... The rear ride height will just help the bike turn in faster, not that its slow its just faster is better
Throttle control might be right but it isnt me being jerky with the throttle its the power I guess compressing the suspension and the rear shock not being able to compose itself. Full throttle is fine
33bhp restriction - Dyno chart? SVeeedy Gonzales SV Talk, Tuning & Tweaking 8 04-06-10 02:32 PM
Injector flow wojto Bikes - Talk & Issues 0 26-01-08 09:05 AM
HI FLOW oil filter Smudge Bikes - Talk & Issues 8 24-09-07 09:30 AM
Dyno Chart Stu Bikes - Talk & Issues 22 10-03-07 02:04 AM
Tyre cross reference chart 2006 steviemcd Tyres 9 23-02-06 01:34 PM
