Old 20-08-08, 10:15 PM   #11
Default Re: over filled coolant.
The fairly fool proof way I use to check the expansion tank level is to remove the hose and point it up. The level of fluid in the hose is the same as the level in the bottle, lower the hose and when it starts to drip then there be the level in the tank.
I don't believe it's critical, so long as there is space there for the expanding coolant to fill, otherwise there'll be leakage, and so long as there is coolant there to refill the rad when it cools down.
When changing the coolant I run it for a few seconds after filling it and top up by the radiator cap to rid the system of air.
Old 26-08-08, 10:16 AM   #12
AndyBrad
worked brill that, job done
now does anyone know the size of the main seat bolt?
Old 26-08-08, 05:43 PM   #13
Dangerous Dave
Do you mean the bolt that secures the front seat down, its a M8 and requires a 6mm allen key to remove it.
Old 26-08-08, 08:15 PM   #14
I thought it was a 6mmhex?
Old 27-08-08, 06:58 AM   #15
Dangerous Dave
Corrected, it is.... well done Chris.
I just filled up for .............101.9p G Bikes - Talk & Issues 28 13-10-08 10:32 AM
Just filled up then ran out? WTF? krhall Idle Banter 39 08-07-08 06:24 PM
Coolant help therealvw SV Talk, Tuning & Tweaking 3 07-08-07 08:02 PM
Nitrogen filled tyres kcowgergmm SV Talk, Tuning & Tweaking 9 27-03-07 11:20 AM
Filled her up with petrol and now it won't start!!! IanG SV Talk, Tuning & Tweaking 11 16-03-07 01:03 PM
