Old 29-08-08, 12:03 PM   #11
Grinch
Default Re: curvy chain and paddock stand
If your really bored, once you have the chain sorted and lube and the axle nut up tight, wind out the adjuster bolts. They get bloody filthy and tend to jam up, so give them a little clean and give them some copper grease. That way the next time you adjust the chain you not cursing the fact that the adjuster bolts won't move.
Old 29-08-08, 12:04 PM   #12
Grinch
And again make sure you have done the main axle nut up so you don't have to adjust the chain again, just tighten the nuts till they stop.
Old 29-08-08, 12:14 PM   #13
Dangerous Dave
Originally Posted by Nicky S View Post
right so haynes says 65 but the manual for the bike says 47
If it helps I have always torqued it up to 65Nm on all SV's I have worked on, never had a problem.
Old 30-08-08, 09:51 AM   #14
Nicky S
Nicky S's Avatar
kk yea 65 sounds a lot more safer then 47 cheers guys :P
Nicky S is offline   Reply With Quote
Old 30-08-08, 09:57 AM   #15
More torque does not always = safer.
Old 30-08-08, 10:07 AM   #16
AndyBrad
agreed. you can easily over torque something dependent of the material specification and application. Also whether the joint is lubricated and what with provides a significant increase in the tensile stress in a fixing.
real work example is i over torqued the wheel studs on a mini, causing the nuts to shear and loosing a wheel. be careful.
And on that note does anyone have a link to a mini torque wrench? mine is bloody massive
Old 31-08-08, 06:15 PM   #17
Nicky S
Nicky S's Avatar
k thats a gd point. well seeing as sv book says 47 and haynes says 64 i did it to 52 it fine no problems so cheers
Old 31-08-08, 09:47 PM   #18
ejohnh
I checked the diff between the chain slack on the sidestand and on a paddock stand. There was no noticeable difference*. Now I always align the wheel using ally section straight edges, and adjust the chain tension at the same time - on a rear wheel paddock stand.
*An Abba stand, or any lift which takes all the weight off the rear suspension, will prob result in a a more noticeable difference
Old 31-08-08, 10:57 PM   #19
Yes there is noticeable slackening of the chain on an abba or centre stand, leading to overtightening it. This stretches it as the suspension compresses.
chain adjustment on paddock stand skyline Bikes - Talk & Issues 3 14-03-09 07:02 PM
Adjusting the chain without a paddock stand? TheShadow Bikes - Talk & Issues 25 07-05-08 05:09 PM
Chain maintenance w/o paddock stand Baph Photos 14 26-02-07 01:44 AM
Storage: Side stand or rear paddock stand? Maudster SV Talk, Tuning & Tweaking 19 20-01-07 04:45 PM
Do I need a paddock stand to adjust the chain? thor Bikes - Talk & Issues 16 10-04-06 08:10 AM
