#11 |
I don't know what you're all on about
#12 |
is it worth doing on a mildly tuned (system and filter, K3 cams possibly later) engine zadar?
#13 |
not in my opinion.maybe with built motor and fancy fuel.
I used it on very built motor but for retard,not advance. |
#14 |
I always felt the advancer gave a nice low-end boost, but then I was less choosy back then and it could have been Modder's Disease... No idea now, I might take mine out and see if I can tell the difference.
#15 |
Ref: I used it on very built motor but for retard,not advance.
That'll be why you never noticed a different ! Retarding the ignition will make it bang far too late when the piston is allready on it's downward stroke. You just detuned the engine. |
#16 |
Ah, you slot the pick up not the trigger. Now I'm with you. Which way do you go ? Clock wise I imagine if an anti clockwise adjustment on the trigger advances. Any body got any pics ?
#17 | |
my dyno testing I mentioned was done on stock motor. yes,clockwise for advance. |
#18 |
Yeah, it sure is a black art. You must have been running a high compresion ratio ?
I used to have a problem with pinking on an A+ turbo engine I built. I was using 10.5:1 compression to negate some of the turbo lag from running a Garrett T3. Worked great untill I blew the piston to into a million bits. It would have been fine if I'd left it running 0.5 bar but I couldn't resist playing with the boost pressure. Damn cabit mounted bleed valves !! |
#19 |
#20 |
is this the little feller I need to slot? The strip metal bracket it's sitting on ?
Cheers guys. [img=http://img364.imageshack.us/img364/7688/pickupug7.th.jpg] ![]() |
ignition advancer | svryanpompy | SV Talk, Tuning & Tweaking | 3 | 18-03-07 12:15 AM |
ignition advancer | svryanpompy | SV Talk, Tuning & Tweaking | 22 | 08-03-07 03:46 PM |
ignition advancer | svryanpompy | SV Talk, Tuning & Tweaking | 6 | 07-03-07 10:59 PM |
Ignition advancer? | sixstring | SV Talk, Tuning & Tweaking | 19 | 22-07-06 06:39 PM |
Ignition advancer?????? | bobbydee | SV Talk, Tuning & Tweaking | 10 | 16-03-05 06:04 PM |
